Tip & How-To about Vacuums
Bissell Bagless Upright Vacuum not working
If your Bissell upright vacuum cleaner is not cleaning like it did when it was new, then you need to provide a bit of maintenance or service. I will tell you how you can do this maintenance to your Bissell vacuum.
First, make sure that your floor vacuum is unplugged. Then you can work safely on your Bissell bagless vacuum.
If your Bissell upright vacuum is losing suction, then the next thing to check is the canister. It is very easy to simply forget to dump the canister.
The while you have the canister out, check the filter inside the canister to make sure that it is not plugged full of dirt. This filter can be difficult to access, but a little persistence will pay off. When you get the bottom of the cup open and remove the filter, use a bit of soapy water to wash out the filter. You can then reassemble the filter into the bottom of the canister.
On the left side of the vacuum there is also a HEPA filter Bissell has there to help filter the air even more. Remove that, clean it also and replace it.
The hose is the next thing to check. You can completely detach the hose from the vacuum. Check the hole at the bottom where the hose hooks up to make sure the hole is not plugged. Then stretch out the hose and run something like a coat hanger through it to make sure that there are no obstructions inside the hose. You should be able to hold the hose up to a light and see right through it.
The last thing to check is your Bissell vacuum belt. If the belt is too loose it will slip and not spin the brush properly. Bissell belts can be purchased online easily, or in many grocery stores. If your Bissell upright cleaner has a slipping belt, it may also be because of strings, carpet pieces, etc… getting wrapped around the brush. Remove the vacuum brush and cut off everything that is wrapped around it. Always be careful of the vacuum belt after you have just used your vacuum. The belt will be very hot just after use.
These steps will help you to get your Bissell upright vacuum cleaner working like new again.
Vacuums Logo
Have a vax steam cleaner today it all of a sudden stopped working lights and everything,any help appreciated cheers
Hi Fraser! I'm sorry your ProHeat Plus has stopped working. I understand how frustrating this must be.
You may want to have a Qualified Tech at one of our Authorized Service Centers inspect your machine. Here's a link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
I'm also providing you with a link to view our current deep cleaning machines: http://www.bissell.com/upright-carpet-deep-cleaners/?cid=ccsocial
Sep 11, 2013 | Bissell 1698-1 PowerSteamer ProHeat Plus...
my bissell will not stay on
turning off is probably most likely caused by over heating because the filters are clogged and need to replaced or cleaned.if you are in Colorado bring it in to the Bissell vacuum cleaner centerBagless vacuum owners have the misconception of maintenance free and part free vacuuming. Every Bagless vacuum machine has filters that need to be replaced usually every 6 months. That same filter also needs to be cleaned monthly or bi-monthly depending on usage.
Jun 05, 2012 | Bissell 6594 PowerForce Bagless Upright...
bissell pro 2x the cleaner solution & water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
shg
Jul 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
installation of pump for bissell steam cleaner
heatman101 //,.
May 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
7,212 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
