Tip & How-To about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer F02 or F21 error code.
This error code indicates that drain times are longer than expected.
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds will slow or stop the removal of water from the washer.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Temporary fixes:
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
Whirlpool Duet GHW9150P Front Load Washer Logo
error code ld
Click the following to learn more about proper drain systems for BravosTM washers. The example shown is for an impeller washer but is applicable to washers with agitators.
Is the drain hose kinked or clogged?
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 39" (99 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and both of the questions above have been checked, call for service.
Hope this helps.
Jun 29, 2011 | Maytag Washing Machines
machine not working (whirlpool duet fron load) error code f21
This error code indicates that drain times are longer than expected. This could be a problem with one of the washer parts including the drain pump itself, how the drain hose enters the stand pipe, or maybe something is stuck somewhere in the drain system and is preventing the water from flowing properly.
Remove the three screws that hold the lower access panel in place. Here you will find the pump and the all important sump clean out, or as we like to call it, the coin catcher.
Jun 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
machine is on but not working screen is flashing LD unplugged it and replugged & still not working, making sounds but not functioning
Sorry to read about your problem, I hope this helps you out.
LD error code indicates that drain times are longer than expected.
you mat have a clogged drain hose, or the pump is clogged.
securing_drain_hose_to_standpipe.jpgsecuring_drain_hose_to_laundry_tub.jpgsecuring_drain_hose_to_wall.jpg
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have an F02 error on my fagor washing machine any ideas?
This error code indicates that drain times are longer than expected.Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. The excess suds will slow or stop the removal of water from the washer.
Mar 29, 2010 | Washing Machines
code f 02 and it is normally in the drain cycle.
Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
2,917 people viewed this tip
Sal De
Gerry Harvey
Gerry Harvey
