Tip & How-To about Washing Machines
How to maintain your Front loader washing machine.
To maintain your front loader washing machine in good working order and to avoid having a service call there are a few simple maintenance tasks to carry out.
1. Every time you carry out a wash before you switch on the unit you should check the door seal for any foreign particles like coins or hair clips and remove them. If they stay there they can then get past the seal and clog up the fluff filter and drain pump which stops the unit from draining.
2. It is also a good idea to wipe the door seal occasionally
3. There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap. Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand.
Also have a look in the hole and you will see the drain pump at the back. Make sure this is free of any foreign particles and can turn. Then re-screw the tap back making sure it is tight.
This should be done regularly every 2-3 months to avoid the unit from not draining.
4. Running a cottons 95c wash every 2-3 months kills off any bacteria build up, and cleans out any excess detergent build up. It also stops the unit from smelling.
You can also use a special washing machine cleaner or just white vinegar as a cleaning agent in the detergent tray to help.
5. After every wash keep the door open for about 30 mins to let it dry out as shutting the door is then a perfect environment for bacteria to develop and the door seal to go mouldy and also causing the unit to smell.
6. Lastly take care when removing clothes as zips can catch on the rubber door seal and tear it. This will then leak water at the bottom of the door.
Hope this helps.
Washing Machines Logo
I have a samsung front loader WF7700N6W1 WHICH KEEPS COMING UPWITH THE ERROR CODE 3E IVE checked the drainage plug and cleared that but mavhine still not working.
The 3E error code to indicate a drive motor tach fault.
Here's a good website that discusses how to troubleshoot and possibly repair. (Could be as simple as unplugging the machine for a few minutes).
How To Fix 3E Error Code On Samsung Washing Machine
Here's an EXCELLENT YouTube video on removing the motor and replacing the brushes (if equipped).
Samsung Washing Machine 3E Error Code not spinning or turning
Jun 15, 2017 | Samsung Washing Machines
To maintain your front loader washing machine in good working order and to avoid having a service call there are a few simple maintenance tasks to carry out. 1. Every time you carry out a wash before you switch on the unit you should check the door seal for any foreign particles like coins or hair clips and remove them. If they stay there they can then get past the seal and clog up the fluff filter and drain pump which stops the unit from draining. 2. It is also a good idea to wipe the door seal occasionally 3. There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap. Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand. Also have a look in the hole and you will see the drain pump at the back. Make sure this is free of any foreign particles and can turn. Then re-screw the tap back making sure it is tight. This should be done regularly every 2-3 months to avoid the unit from not draining. 4. Running a cottons 95c wash every 2-3 months kills off any bacteria build up, and cleans out any excess detergent build up. It also stops the unit from smelling. You can also use a special washing machine cleaner or just white vinegar as a cleaning agent in the detergent tray to help. 5. After every wash keep the door open for about 30 mins to let it dry out as shutting the door is then a perfect environment for bacteria to develop and the door seal to go mouldy and also causing the unit to smell. 6. Lastly take care when removing clothes as zips can catch on the rubber door seal and tear it. This will then leak water at the bottom of the door. Hope this helps.
Mar 26, 2010 | Kitchen Appliances - Others
i have a indesit IWB5123 washing machine it takes the powder then stops working all together what is wrong
These front loaders had a poorly engineered filter system, and would often clog and stop working. you have to remove the door, then the giant rubber seal in order to access removing the front panel. you can follow the drain lines to find it, clean out the filter ( it will stink) and hopefully this helps. its a good bit of work, but its pretty simple to figure out
Jul 15, 2014 | Washing Machines
door lock creda front loader
Read through the following manual and please let me know if this is effective.I have suggested the same to several other people and they found it useful.It deals with simple instructions to solve washer problems.Just to avoid a lot of cost on the technician.Good luck.And please do check the following link.
click here for washer problem solving
Also please do rate my answer if accepted.Thank you.
Jan 20, 2009 | Creda W120VW Front Load Washer
225 people viewed this tip
Top Washing Machines Experts
