Tip & How-To about Medical
How to repair a fukuda ekg machine
If the paper does not move ,clean the rollers with scotch tape this will remove the wax and lint left behind from the paper. you can contact me at www.medteck.com i will help you.
thank you
Freddy
Medical Logo
Paper keeps jamming after 10 -20 sheets,please help
if your fuser rollers look clean and even it could be pickup issue. It's easy to fix in 3 steps.
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore.
http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Apr 15, 2010 | Brother HL-2040 Laser Printer
Brother HL 2140 does not pick up paper from tray
Make sure your pickup roller clean.
If it's clean and still jams the problem is inside.
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Apr 09, 2010 | Brother HL-2040 Laser Printer
2070 printer shows red, flashing 'paper' lcd when there is paper in the tray. I have done the usual, checking tray, removing and restoring toner cartridge etc etc. I have tried a manual feed as this sometimes 'kick-starts' it continue printing. I have followed the online help to clean the paper pick-up system and I have just followed another on-line help to check the printer properties and paper selection, all to no avail. Any more ideas, please, before I launch it out the office window?
Dec 01, 2009 | Brother HL-2070N Laser Printer
FEEDING PROBLEMS FROM PAPER TRAY
Oleg Andrukh IT Specialist PhillyCopiers.com 215 364 3774
Apr 19, 2009 | Brother MFC-7820N Laser Printer
dell 1700 laser printer wont load from tray only manual
This is a common misconception with this model printer. People say that the roller does not drop down to pick up the paper. With this model printer, the pickup rollers ONLY drop when the paper tray is inserted. If you look on the top left edge of the paper tray towards the front of the printer you will see 1 1/2" to 2" section where the plastic edge is raised about 1/2 an inch. This raised part in the plastic actually serves as the mechanism for dropping the pickup rollers on to the paper.
So... The solution DOES HAPPEN TO BE cleaning or replacing the pickup rolers/tires. Rubber rejuvinator is the best for cleaning the rollers, but buying a whole can that you may only use once or twice may be a bit overkill. You can try cleaning them with soapy water if you do not have any rubber rejuvinator. DO NOT use alcohol, as this will dry out the rollers and shorten their lifespan even more.
Oct 02, 2007 | Dell 1700 Laser Printer
861 people viewed this tip
Top Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
