Tip & How-To about Televison & Video
Troubleshooting? Are Your Voltages Correct!
Before we can attempt to repair anything at all, there is one thing that one MUST do before anything else is done. Now that is, the making sure that the Power Supply,of the unit, no matter what it is, has the correct Voltages, coming into it, and more importantly, coming OUT of it. This is absolutely imperative, as, IF these Voltages are NOT correct then NOTHING will work, properly at all. So we must measure these voltages with a Volt Meter. or a Multimeter set to DC Volts. ( Always use a good quality meter, as if your meter is bad, so are your readings, and we can need to read to within, +/- 0.1 Volts). All Voltage measurements are made with reference to ground. Meaning we clip, our Black, Minus, Lead onto the Earth, or Chassis, or Negative (-) "Rail" of the Power Supply. Now with the Red lead, we can now, measure these Voltages. Now sometimes, the Voltage of each Output is annotated,or written, onto the PCB, that will indicate the Voltage of that output. However most usually they are NOT, so in this case we MUST have a manual to tell us. Now this manual is called a "Service Manual" or sometimes a "Repair Manual" This manual, is absolutely vital, so much so, that it can be near impossible, to do without it. To Order ANY "Bits" you need the parts, "Part Number" a Number that "Identifies" it to the Factory, so we/they know what it exactly is. Without that number you simply cannot get the correct parts. Also too, apart from having "Troubleshooting" step through's, it also has our Voltages. When we measure these Voltages they are 100% EXACT, so IF the Voltage you measure, except for a few rare exceptions, the "Rail" that is NOT at the correct voltage is the one, that the "Fault/Cause" is "ON". Therefore we can now work outwards from the Power Supply, looking for the cause of that problem. Now if the Voltage is Lower than specified, we are invariably looking for a "Short", something has "Faulted" and is "Dragging" the Power Rail down to earth. possibly a Capacitor, or Diode, or an IC. Now if the "Rail" is "Higher" than the specified Voltage then the fault we are looking for is usually some sort of "Open Circuit" possibly a Diode, or Resistor, that has changed it's "Value", due to heat or stress. Now knowing this, and knowing that, the Power Supply is the FIRST & ONLY place to start you troubleshooting and repair from. You now have a MUCH better chance of a "Fix". One thing more, DO NOT forget to get your SERVICE MANUAL. for you exact make & model. even if you pay for it, you will be glad you did.
Televison & Video Logo
what causes light to blink every 5 seconds when switch is on?
Hello,attempting repairs yourself,may save money.But if you do not fix the repair,then seek a repair shop.Could leave you on your own,as it could now become a bigger job with them trying to work out what you have done.Some may not even look at it when they learn you attempted it yourself.I would email/call or visit a repairs address with the flashing defined and ask for a price for repairing it.You can find your nearest repair address by typing your request for your product into your browser from your Post Code.1 thing I would say:Anything you do yourself,take a separate photo on your mobile for referring back to.It could be that Control System in Sleep Mode.I hope this helped you,Colin
Feb 28, 2015 | Health & Beauty
what does a B1 service light mean on a glk mercedes
It simply means that you are due for a "B" service. This includes and oil and filter change, along with a comprehensive inspection.
Jan 26, 2013 | 2010 Mercedes-Benz GLK-Class
lens problem
Sorry, but there's not a safe or sure DIY fix for the lens problem, and any attempts at a homebrew repair will likely make things worse. Your camera needs professional attention, so I suggest that you take it to a local camera shop (NOT the camera department at a chain store) or contact the factory support folks via the Kodak.com web site to arrange repairs. Be sure to get a firm price, not just an estimate, before you commit to anything. Cost for the fix can approach the price of a new camera, and repairs typically only carry a 30-day warranty.
BillB
Jan 05, 2010 | Kodak EASYSHARE M340 Digital Camera
1613EVS Plunge Router will not operate. Does not start !
hello- had same problem with similar model-- problem is definitely DUST INSIDE THE SWITCH, it must be blown out with compressed air- i had this done at a repair shop (for free) so i don't know if they had to disassemble anything- hope this is helpful
john
Nov 16, 2008 | Bosch Plunge Router
Camera does not work
I am having this same error message appear on my phone but this is not the camera its the messages on mine, i can't send or recieve any messages. Suggestions have been made to me that i do a master reset on my phone so you could always try the same thing. Everything will be wiped from the phone so make sure to back up files you want to keep.
Apr 01, 2008 | Nokia 6288 Cellular Phone
239 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
