Tip & How-To about Office Equipment & Supplies
Power saving mode officejet 6500 series
Did you know that officejet 6500 series doesnt have any configuration about power saving mode (sleep mode).
it will turn to sleep mode after 1 hour.
if it is wireless, you need to turn off/on the product for you to use it again
I have an HP office jet 4500. How do I turn off the sleep mode? I am having to unplug it everytime now to get it to turn back on.
Sleep mode option for avoid consumption of power which was widely used in high end laser technology to save power. This option is not avail in inkjet technology where that much power not required..Even power saving mode not switch off entire internal functions except fusers/heaters.
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
Can't get the Power Save Mode to turn off
Try looking on the front panel of the printer
press set up button look for Tools or Preferrences then look for power saving mode then turn it off
If the front panel cant have it,connect it directly on a wall outlet not power strip
or more advance
press * and # at the same time then press 1234 consecutively then underware menu should appear on screen
if it does not show you that just keep on doing it until it appears
then use arrow keys and look for sleep mode/power saving mode then set it to 0 or off
Hope I help you a bit.
Your's Truly,
Christian from HP
Mar 23, 2011 | HP Officejet 6500 Wireless All-in-One...
have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it
Power Save Mode.Just press the on/off button or wait for the printer to wake up when you start a print job.
Nov 07, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you turn off sleep mode on the hp officejet 4500?
This no doubt violated the warantee, but I got tired of turning the printer around and unplugging the power cord etc.
So I got a cord switch I had (Ace hardware 31089, others will not doubt work) and installed it in the power cord per directions.
Now it is easy to reach behind printer and cycle the power with the power cord switch and thus wake up the printer.
May 20, 2010 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Jan 17, 2010 | HP Office Equipment & Supplies
262 people viewed this tip
jasbo
jasbo
