Tip & How-To about Kirby G6 Bagged Upright Vacuum
How To Replace The Belt On a Kirby G6 Generation Vacuum Cleaner
Greetings,
Below we have recorded a video on how to replace the belt on a Kirby Generation Series G6 Upright Vacuum Cleaner. This easy to understand video will explain step by step how to change the belt, as well as service the roller brush. Learn how to lower the brushes as the beater bar wears out, and how to prolong the life of your belt by doing regular maintenance on the roller brush.
The repair is the same for all Kirby Generation Uprights. I hope this helps everyone! Feel free to contact us if you have any questions about vacuum repair.
If this video was helpful, please be sure to rate it as helpful by clicking the thumbs up icon at the bottom of the repair. Thanks for watching!
Chris J.
GoVacuum
Kirby G6 Bagged Upright Vacuum Logo
i need to know how to put my belt back on my kirby 2000 G6 vacuum belt
Greetings from GoVacuum,
Here's a very informative video that we've recorded explaining in detail how to correctly install the belt on your Kirby Generation vacuum cleaner. I hope this will help you.
Kirby Belt Change Video;
If this video was helpful, please be sure to rate this Solution by clicking on the 4 Thumbs Up icons in the top right hand corner of the page. If you have any questions, please feel free to email me, I'm more then happy to answer any questions you may have.
Chris Jones
GoVacuum.com
Mar 02, 2010 | Kirby G6 Bagged Upright Vacuum
how do I replace the drive belt on a Kirby G5 vacuum cleaner?
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners including your Generation 5 (G5). The belt change procedure is the same for Kirby Models G3-G10 Sentria. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
I hope this video was able to teach you the exact process of how the Kirby belt has to be installed in order for it to work properly. Please, if you have any questions just request a clarification of the repair and I'll be more then happy to help you further, I'm always happy to answer any questions. If you found this video helpful, please kindly rate this repair solution as helpful also. I really do appreciate it, thank you.
Chris J
Jan 20, 2010 | Kirby G5 Bagged Upright Vacuum
My belt broke on my kirby G-5. I havent put a belt on it in 10 years. I having problems getting it on.Can u tell me the right way? Thank you.
Greetings,
I recorded a video repair of replacing the belt for the Kirby generation vacuum cleaner. The following video will walk you through step by step on how to replace your Kirby belt, as well as doing some basic maintenance to the roller brush to prolong the life of your belt as long as possible.
How to Replace the belt on a Kirby Ultimate G Vacuum Cleaner;
I hope that this video was helpful to you in repairing your Kirby. If you found the video to be helpful, please kindly rate the video helpful by clicking on the Thumbs Up Icon below.
Chris J.
Nov 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Chris J.
Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
700 people viewed this tip
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
