Tip & How-To about Kirby G4 Bagged Upright Vacuum
How To Change The Fan or Impeller Blade On a Kirby Generation Vacuum
Greetings,
Below we have shot a video on how to replace the fan blade (also known as the Impeller Blade) on a Kirby Generation 4 Upright Vacuum Cleaner step by step in an easy to understand format. If you'd like to see a repair done by video, please contact us. Also be sure to stop by our website for all of your Kirby Vacuuming needs;
Part 1
Part 2:
If you found this repair video helpful, please be sure to rate the repair as helpful by clicking the Thumb Up Icon at the bottom of the repair page. Feel free to contact me if you have questions on how to do it, or how to purchase the part.
Thank you,
Chris J.
GoVacuum
Kirby G4 Bagged Upright Vacuum Logo
when replacing the fan impellar on the kirby generation what is the order of the bushings that comes with the kit
I've shot a very helpful video walking you through step by step on how to replace the impeller blade on a Kirby Generation vacuum cleaner.
The exact answer to your question should be contained in the Part 2 of the video.
Part 1;
And the second and final part;
I hope this was helpful to you, and was able to answer your questions. If you have other questions, or still need help, please feel free to use the comment field at the bottom, I"m always more then happy to answer any questions you may have. If you found this to be helpful, please be sure to rate my repair helpful, or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Kirby Generation 3 Bagged Upright Vacuum
I need to replace the fan and am not sure Kirby G 4 A
Greetings from GoVacuum,
We've shot a video showing you detailed instructions on how to replace the fan on a Kirby Generation vacuum cleaner. The video is in two parts below. If this video was helpful to you, please be sure to rate this Solution by clicking the four Thumbs Up icons in the top right hand corner of this Solution;
Changing the Fan On a Kirby Generation Video, Part 1:
Kirby Fan Change Video Part 2;
Thanks,
Chris Jones
GoVacuum.com
Mar 03, 2010 | Kirby G4 Bagged Upright Vacuum
how do you change the belt on a kirby g4 vacum
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners, including your Generation 4, G4. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
I hope this video was able to teach you the exact process of how the Kirby belt has to be installed in order for it to work properly. Please, if you have any questions just request a clarification of the repair and I'll be more then happy to help you further, I'm always happy to answer any questions. If you found this video helpful, please kindly rate this repair solution as helpful also. I really do appreciate it, thank you.
Thanks for watching!
Chris J.
Feb 20, 2010 | Kirby G4 Bagged Upright Vacuum
1,364 people viewed this tip
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
