Tip & How-To about Tomtom ONE 3RD EDITION GPS Receiver
Quicker Startup/Shutdown
Plug in device and view memory contents, delete the startup/shutdown(antitheft) images (back them up if you want).
Unit should startup/shutdown faster now.
You could also use this method to change the images to your own personalized startup/shutdown pics. Just copy over your pics, and name them to the same names of the images that were on the tomtom.
Tomtom ONE 3RD EDITION GPS Receiver Logo
Custom Content Issues on Fiat TomTom Blue&Me 2
It can be done but its not easy.
1. Borrow a tomtom off a friend that has an older version that connects upto tomtom HOME and not My Drive connect.
2.Make a copy of the contents of that device onto the desktop of your pc. (*create a folder and call it tomtom)
3. Now on the copy, your done with the borrowed unit. Open the map folder and add the 'car' images you want into the 'brand' folder. If it doesnt exist create one in the map folder naming it 'brand'
4. Now copy everything onto a SD card
5. Go onto tomtom website and download 'tomtom content transfer assistant' and install
6. Connect your newer device to the pc and run the connect assistant.
7. Plug in the sd card when asked (connect old device)
It will then copy start up, shut down images, brand folder over to the new unit.
This should allow what ever you put in the brand folder to be displayed.
Jan 22, 2014 | Tomtom GPS
Memory card is full and when I plug in the USB cord and turn on the camera I get a message that my device is not connected or is busy, or that it contains no pictures!!
Causes of memory card corruption
  • Turning off a camera before an image is completely written to the memory card.
  • Removing the memory card from a camera while an image is being written to the card.
  • Removing the card from a memory card reader while files are still being transferred to a computer.
  • Batteries conking out as files are being transfered directly from the camera to a computer. Note: always make sure you have fully charged batteries before transferring images.
  • Removing the card from a card reader while folders and files from the card are open on a computer.
  • Opening, deleting, renaming or moving files on the card while its contents are open on a computer.
  • Using a memory card which has not been formatted in the camera. Use the delete/erase function when needed, however a card should be regularly formatted.
  • Formatting a card in a computer instead of the camera.
  • Inserting a second memory card into a card reader before closing and removing the first when viewing images on the card from a computer.
  • Taking photos when camera batteries are nearly empty.
  • Taking photos too rapidly so the camera can not complete writing one image before starting the next.
  • Continually shooting and deleting, shooting and deleting images when the card is full.
  • Letting a memory card get too full before downloading the images to a computer or storage device. Cards that are too full may overwrite the card headers.
  • Using a memory card from one camera in a different camera without formatting it in the new camera first.
Feb 28, 2008 | Cameras
delete select pictures from camera
While viewing the image, press the trashcan button. The camera will ask for confirmation of the delete.
I would recommend against making a habit of keeping some pictures on the camera or memory card and deleting others. You're guaranteed to fragment the memory, leading to camera speed loss and eventual memory corruption. The camera is an image capturing device, not an image storage device. If you need to keep some pictures on the camera, copy them to a computer, format the memory card, and then copy them back using a card reader.
Mar 18, 2012 | Canon PowerShot SD1100 IS Digital Camera
Frozen screen cant turn on or off.
Hi! I've just finishing dealing with this on my Go720.
Symptoms - freezes during startup and can not turn off.
Tried resetting - but this only turns the unit off. When it tries to restart it still freezes during startup sequence.
So - connected to PC and ran TomTom HOME2. I had backed the unit up only a few month previous, so I tried to do this. However, it threw an error on this procedure. I then thought that perhaps I could erase the memory contents and reinstall the contents of my backup folder. However, playing safe, I first wanted to do a dump of all my files on the units internal memory. Halfway through this I had an error message saying that one file was corrupt and could not be read. The file was clmdata. So ... after more researching the web I read that the file clmdata has been blamed for this freezing problem. I examined my Go720 internal memory and tried to overwrite the corrupt clmdata with the one from my backup set. That failed as the file was corrupt. In windows explorer then deleted the clmdata file but all this did was generate a file of 0 bytes with the original name. However, I now tried again to restore the unit with TomTom HOME, and this time it worked. Unit is fine now! From what I've read, you may not need to use the restore function, but just delete (or try to delete) the clmdata file, and the unit recreates it when it restarts. Best of luck!
Jeremy
Sep 10, 2011 | Tomtom GO 910 GPS Receiver
not found music player
im sorry about that!!
i went to
http://nds1.nokia.com/phones/files/guides/Nokia_3110_classic_UG_en.pdf
Your device includes a music player for listening to music tracks or other MP3 or AAC sound files that you have downloaded from
the web or transferred to the device with Nokia PC Suite. See "Nokia PC Suite," p. 40.
Music files stored in the music folder in the device memory or on the memory card are automatically detected and added to the
music library during the startup of the device.
To open the music player, select Menu > Media > Music player.
to manage the songs and stuff like that:
Copyright protections may prevent some images, music (including ringing tones), and other content from being copied,
modified, transferred or forwarded.
Manage images, video clips, music files, themes, graphics, tones, recordings, and received files. These files are stored in the
device memory or an attached memory card and may be arranged in folders.
Your device supports an activation key system to protect acquired content. Always check the delivery terms of any content and
activation key before acquiring them, as they may be subject to a fee.
Folders and files
To see the list of folders, select Menu > Gallery.
To view the list of files in a folder, select a folder and Open.
To see the available options of a folder or a file, select a folder or a file and Options.
To view the folders of the memory card when moving a file, scroll to the memory card, and press the scroll key right.
****IF ITS MISSING ALL TOGETHER:
To reset some of the menu settings to their original values, select Menu > Settings > Restore factory sett.. Enter the security
code.
The names and phone numbers saved in Contacts are not deleted.
I hope this helps!!!!
Dec 24, 2010 | Nokia 3110 Cellular Phone
1,719 people viewed this tip
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
