Tip & How-To about Cameras
Why do my Digital camera batteries die so fast?
All digital still cameras suffer if the battery terminals aredirty. Using a Q-tip and 99% pure alcohol, clean the battery terminalsin the camera and on the batteries BEFORE you put them back in.
If you get good results, let me know.
Also, batteries specifically for digital cameras, like Duracell Ultra and Eveready e2 are WORTH the money.
Regular batteries 20 shots, special batteries, 144 shots with flash and counting...
Cameras Logo
i have a 10d digital camera. battery gos dead after shooting 15+
Try cleaning your battery terminals. You can use a little rubbing alcohol on a q-tip. If you are still having issues then you will need to get another battery as that battery is shot
May 27, 2010 | Canon EOS-10D Digital Camera
my camera shuts off right after power it on
This could have several causes. If the camera works OK on external power, try this...
Digital cameras suffer if the battery terminals are dirty. Using a Q-tip and 99% pure alcohol, clean the battery terminals in the camera and on the batteries BEFORE you put them back in.
Regular batteries 20 shots, special batts, 144 shots with flash and counting...
Mar 28, 2010 | Polaroid i1035 Digital Camera
uses batteries very quickly and then shuts down until change to new batteries
Try this before you throw away the camera.
Mar 22, 2010 | SVP CDC-8680 Digital Camera
batteries canon ixus 400
Canon (and all digital cameras) suffer if the battery terminals are dirty. Using a Q-tip and 99% pure alcohol, clean the battery terminals in the camera and on the batteries BEFORE you put them back in.
Mar 20, 2010 | Canon Cameras
my camera is not getting switched on. instead the
Hmm... What kind of batteries are you using? Does this happen on the charger power? If so, it definitely needs repair.
If batteries only:
Try using batteries specifically for cameras - they are worth the money.
Try cleaning the battery door with a little 99% pure alcohol and a Q-tip. This can make a BIG difference if it is battery issues.
Rechargeable batteries may not work well. Try cleaning both ends of the batteries with alcohol as above. If the rechargeables are over 3 years old, they may be toast.
Jan 28, 2010 | Canon Powershot SX110 IS Digital Camera...
1,224 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
