Tip & How-To about Dryers
How to Install the Heating Element of Maytag Amana Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.2) There are two panels in the dryer. One is top and other is front panel.3) Both the panels are secured by clips in between them.4) Take a putty knife and insert it in between the top panel and the front panel of the dryer. Press the retaining clips with knife and separate the top and front panel by Lifting up on one corner of the top panel to release the opposite retaining clip.5) After the clips are pressed both the panels will easily get separated. But take care there will be a connecting wires between the panels. You don’t have to pull that wire while separating the panels.6) You will see the door switch on the upper right side corner area of the front panel.7) Remove the wire harness from the door switch carefully.8) The remove the flange of the front panel to the side panel on each side by removing the screws.9) The front panel will get separated from dryer after removing the screws.10) Now with the help of screw driver remove the screws holding the drum bulkhead of the dryer.11) Now push the idler pulley between the drum and the motor assembly with you hand to loosen the belt tension.12) The belt will easily come out one you loosen the belt tension.13) After the belt is out. Carefully lift and remove the drum. Now on the lower rear side you will see the heating element.14) There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.15) Remove the connector carefully from heating element with the help of needle nose plier.16) After the wires are removed from heating element’s terminals.Remove the screws holding the heating element.17) The heating will have to be moved a bit to come out easily. Before removing the heating element out.Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.18) Remove the old heating element and insert the new heating element.19) Connect all the wires as it were connected before.20) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
Dryers Logo
Dryer was working when I left, came home clothes were dry, but now will not restart. Pushing start button does nothing. Light is on in tub when I open door.
this sure has all the suspicions that it's the thermal safety switch , (1) it worked on last load
(2) nothing happens when start is pushed
( 3) tub light works ok
both gas and electric models have one , and they both do go bad , the switch is mounted usually at top of air outlet tunnel on back of dryer , some do have reset buttons , but rarely do they trip for false reasons , something musta happened to cause a high heat build up in dryer ,Lint build-up is most common reason I can think of
May 18, 2015 | Dryers
Get dryer to work, no instruction manual for Indesit Washer WDG 1195 W
What to check when your dryer won't start-
The wall outlet 240 volts:
The first thing to check when your Whirlpool dryer is not starting is the wall outlet to make sure that the dryer is getting the proper voltages. On an electric dryer there should be 240 and 120 volts present at the terminal block.
A blown fuse or tripped circuit breaker are one of the major causes why the dryer won't start. To check the voltage on an electric dryer you will need to use a multimeter.
The wall outlet 120 volts:
A gas dryer connects to a 120 volts wall outlet, and it is very easy to check the outlet. Disconnect the dryer and connect a hair blower or any other small appliance on the outlet.
If they work, then the problem must be on the dryer. If the don't work, check for a blown fuse or tripped circuit breaker. If the problem is bigger than that, have a license electrician check the house wiring. A bad wall outlet could be the reason why your Whirlpool dryer is not starting.
The thermal fuse:
The thermal fuse is use on an electric dryer as a safety devise to open the motor circuit if the operating thermostat fails to open at the preset temperature or if the motor draws too much amperage.
A blown thermal fuse could be the reason why your Whirlpool dryer is not starting. It is located behind the back panel on the dryer.
The door switch:
The door switch is another safety device use on the dryer. It is connected on the neutral line of the motor circuit. A door that is not closing properly or a bad door switch could be the reason why your Whirlpool dryer is not starting.
The push to start switch:
The push to start switch is use to start the motor. There are two types of switches. The older type switch is a solenoid operated door switch and the other one is a simple push to start switch.
A bad solenoid operated or regular push to start switch could be the cause why your Whirlpool dryer is not starting.
The timer:
The timer is the distribution center or the brain of the dryer. Inside of the timer is that the electricity gets routed to the different electrical parts in the dryer.
The timer has contact points, and the contact points wear or burn out depending on the amount of use. Contacts burnt inside of the timer, could prevent the dryer motor from starting..
The motor:
Also, the motor could be burnt bad. A motor that smells like rubber burning, makes growling noises, runs for a wile, the won't start until is cool down or a motor that runs fine, but the centrifugal switch is not making the right connections is a bad motor and must be replace.
So...as you could see, there are many parts that could be the reason why your Whirlpool dryer is not starting.
Feb 16, 2008 | Washing Machines
model #MDE8057AYW I need to know how to get the lid off so I can see if I need a new belt
1.Unplug the electrical cord of the Maytag electric dryer from the electrical outlet.
2.Open the dryer door and locate the four screws on the inside,unfastening the screws with a screwdriver.
3.Pull on the corners of the top front panel,rolling the corners forward to release the clips.
4.Tip the front panel straight out and slide it up until the panel comes loose of the clips.
5.Set the front panel aside and slide the top of the dryer forward.
6.Lift the top of the Maytag electric dryer up,tilting it back and resting it against the wall.
Aug 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
393 people viewed this tip
Top Dryers Experts
