Tip & How-To about Computers & Internet
Cooling Mats a must have for laptops of any kind
One of the biggest enemies of pcs/macs and laptops are heat.
A great way to prevent this is a simple little item called a chill mat
when you go to buy a laptop or already have one dont forget to pick one up they plug into your usb port and keep your laptop from overheating many like the Swiss Army brand even have pull out arms to hug your laptop and fit on your lap and easily into your laptop bag with it they run under 50.00 bucks and are a great item for keeping your laptop healthy
Computers & Internet Logo
Samsung Laptop Shuts Down Unexpectedly
CHECK THE FANS! The biggest enemy to your laptop is HEAT! You just replaced the display it's very possible you inadvertently disconnected the cooling fan. Clean it while you have it apart dirt and dust prevent proper cooling
Jun 28, 2017 | Samsung Computers & Internet
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Video Quality Problems
Hey,
the laptop is overheating and shuts down to prevent hardware failure. Use canned air to blow dust out from the fans that may improve it a little.
Feb 18, 2009 | Toshiba Computers & Internet
targus chill mat not working properly
This problem is being caused by a wire becoming disconnected from the switch in the usb power cord. The easiest way to solve this problem is to open the switch using a flat blade like a knife, and either reconnect the loose wire yourself or to completely remove the switch and connect the wires together completing the circuit and allowing the fan to operate. I hope this helps.
Oct 30, 2007 | Targus Chill Mat PA248U Laptop Cooler
185 people viewed this tip
David Payne
David Payne
