Tip & How-To about Dryers
How to Replace Heating Element from a Maytag Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
4) The heating element is located in the cabinet.
5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
6) Locate the heating element cabinet and remove the screws holding the cabinet.
7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
8) Remove the connector carefully from heating element with the help of needle nose plier.
9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
11) Remove the old heating element and insert the new heating element.
12) Connect all the wires as it were connected before.
13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
Dryers Logo
LONG DRYING TIME
Most likely the vent is plugged - check the vent hose (usually start at the outside location & work back to dryer). If hose is not clogged, unplug dryer, remove vent hose from back of dryer and check there.
Aug 02, 2012 | Roper REX4634KQ Electric Dryer
2004 ford taraus transmission burps fluid after turning off car
Hi, welcome to FixYa.com my name is Shawn and I will be answering your question.
FORD: 2000-2007 Taurus
2000-2003 Windstar
2004-2007 Freestar MERCURY: 2000-2005 Sable
2004-2007 Monterey
This article supersedes TSB 05-14-5 to update the Service Procedure and vehicle model years. ISSUE: Some 2000-2007 Taurus, 2000-2005 Sable, 2000-2003 Windstar, and 2004-2007 Freestar/Monterey vehicles, equipped with a 4F50N, AX4N, or AX4S transaxle, may exhibit an erratic fluid level reading on the transaxle dipstick and possible leaks around the filler tube and grommet. The condition may be due to a restricted transaxle vent.
ACTION: Repair the transaxle vent restriction by replacing the transaxle vent with a 90° vent stem, small hose clamp, two (2) tie raps, and 24" (61 cm) of 5/16" (8 mm) vacuum hose. The 5/16" (8 mm) vacuum hose will be routed from the 90° vent on the transaxle back to the cowl area, next to the brake master cylinder and tie rapped in place with the end of the hose facing down. Refer to the following Service Procedures.
NOTE: ON WINDSTAR, FREESTAR AND MONTEREY SEAL THE COWL PANEL GRILLE (COWL TOP VENT PANEL) AREA, SEE TSB 06-14-10. NOTE: LEAKS MAY BE MISDIAGNOSED AS COMING FROM THE PAN GASKET. ALWAYS FOLLOW WORKSHOP MANUAL, SECTION 307-01 TO LOCATE THE SOURCE OF A LEAK, AND LEAK CHECK WITH BLACK LIGHT AND DYE. SERVICE PROCEDURE
  1. Disconnect the mass air flow (MAF) sensor electrical connector.
  2. Disconnect the crankcase vent tube(s) from the air cleaner outlet pipe.
  3. Loosen the clamp and disconnect the air cleaner outlet pipe from the throttle body.
  4. Release the air cleaner housing clamp(s).
  5. Separate the air cleaner cover from the air cleaner tray.
  6. Windstar, Freestar and Monterey only: Remove cowl panel grille by following the procedure in TSB 06-14-10.
  7. Disconnect the shift cable if located over the top of the vent.
  8. Remove the vent, pull straight up on the vent with locking pliers, or carefully pry the vent from the transaxle case.
  9. Install the replacement 90° vent stem.
    • Windstar, Freestar, Monterey, Taurus, and Sable with column shifter - Must face to the right rear of the vehicle with the flat edge of vent base parallel to the chain cover boss (Figure 1)
    • Taurus and Sable with floor shifter - Must face to the rear of the vehicle with the flat edge of vent base parallel to the chain cover boss (Figure 2)
    Figure 1 - Article 06-18-13
    Figure 2 - Article 06-18-13
  10. Install one end of a 24" (61 cm) long piece of 5/16" (8 mm) vacuum hose to the 90° vent stem and secure with a small hose clamp.
  11. Route the vacuum hose back and up to the cowl area and down next to the brake master cylinder. Carefully tie rap the hose in place next to the brake master cylinder (do not tie rap to brake lines), be sure the end of the hose is facing down and not directly above anything hot.
    • Windstar, Freestar, and Monterey (Figure 3, 4, and 5)
    • Taurus and Sable with column shifter (Figure 6)
    • Taurus with floor shifter (Figure 7)
    Figure 3 - Article 06-18-13
    Figure 4 - Article 06-18-13
    Figure 5 - Article 06-18-13
    Figure 6 - Article 06-18-13
    Figure 7 - Article 06-18-13
  12. Connect the shift cable, if removed.
  13. Install the air cleaner cover and outlet pipe. NOTE: USE THE ALIGNMENT NOTCHES TO CORRECTLY ALIGN THE AIR CLEANER COVER TO THE AIR CLEANER TRAY.
  14. Install the air cleaner housing clamp(s).
  15. Connect the air cleaner outlet pipe to the throttle body and tighten to 35 lb-in (4 N-m).
  16. Connect the crankcase vent tube to the air cleaner outlet pipe.
  17. Connect the MAF sensor electrical connector.
  18. Windstar, Freestar, and Monterey only, follow TSB 06-14-10 to seal and install the cowl panel grille.
PART NUMBER PART NAME 1C3Z-7034-AA Vent
I hope my assistance helped you and resolved your concern, if you need further assistance please ask.
Aug 07, 2011 | 2004 Ford Taurus
hama 00086510
Instructions
Things You'll Need:
* Fuse
* Electrical device
* Lint removal kit
1. Check that you've plugged the dryer in. If the dryer is not receiving any electricity, it will not turn on.
2. Plug another electrical device--such as a radio, iron or hair dryer--into the same outlet. If this item doesn't work when plugged in, it indicates that the problem could be with the electrical outlet or the fuse. Replacing the fuse or moving the circuit breaker switch back into place could solve the problem.
3. Clean the lint from all areas. You'll need to open up the vent and dig any lint out. A lint removal kit can help you get the lint out from all the dryer's nooks and crannies.
4. Replace the thermal fuses. If the thermal fuses--there are two--have blown, your dryer won't work. If the thermal fuse turns out to have been the problem, it suggests there may also be a problem with the venting, so be sure to check the venting tubes.
5. Check for loose wires and hoses in the back of the dryer. Wires should have a tight connection and hoses should not have any kinks.
Feb 23, 2011 | Dryers
The dryer appears to be overheating. The top of the dryer housing get hot while drying a load of cloths. More than normal. Checked dryer vent, lint catch (clean) and exhaust hose and all appears clear.
Excess lint can also cause a dryer to get too hot. Again, you should check the filter and the vent for lint. Clean them if needed. Another thing that could cause a dryer to get too hot is a bad blower. This would need to be replaced if damaged. You should also, never use white plastic vent. This can cause your dryer to overheat and also be a fire hazard.
If you are not already a repairman, there will be some problems that arise that you cannot fix. The idea is to know what to look for and to fix whatever problems you can. This way, you don't purchase a new one or call a repairman unless it's necessary. When making repairs, always unplug your clothes dryer for safety. If parts are needed, make sure you have your manufacturer and serial number with you before going shopping. This will help ensure that you buy the right parts and save you another trip to the store. Most of us are intimidated at the thought of dryer repair. Just keep in mind that a lot of common dryer problems are simple (excess lint) and can be fixed by anyoneIf the dryer heats when the Fabric Care/Temperature switch is set to AIR FLUFF (No Heat), check the following:
-HARNESS/CONNECTION
-HEATER RELAY
-FABRIC CARE SWITCH
-EVEN HEAT CONTROL
Procedure:
1. Perform the Fabric Care/Temperature Switch Test
2. Set the following configuration:
Door- must be closed
Fabric Care/Temperature switch- AIR FLUFF
Timer- TIMED DRY
3. Press the PUSH TO START switch
a. Check voltage on Heater Relay. If P3-1 to P3-2 is 0VDC, replace the Heater Relay
b. If P3-2 is 48VDC, replace the Even Heat control.
Dec 05, 2010 | Whirlpool WED8300S Dryer
248 people viewed this tip
Top Dryers Experts
