Tip & How-To about Office Equipment & Supplies
Why your inkjet printers last only one year
Inkjet ink is glycerine and alcohol
Inkjet printers need to be used. You cannot leave an inkjet on a shelf and print only once a year. Use the thing occasionally. Use the same page, both sides, just to run it once in a while. Once a month will usually do.
Inkjet machines that have replaceable individual ink
DO NOT LET THE INK RUN OUT. Have a standby ink for all colours or go and get ink as soon as it runs out. Today will be good. Next week may be too late. Do not remove the ink cartridge until you have a spare to install NOW.
Inkjet with all colours in one cartidge, black with a metal bottom, black and colour with a metal bottom on each.
It does not matter if these run out of ink. The whole cartridge must be replaced. If you refill your ink at a store, place the cartridge in a ziplock bag and seal it. Take the cartridge in the same day for best results.
If you refill your own cartridges, do it right away for best results. Press the refilled cartidge head on a clean paper half a dozen times to see if you get nice clear bands.
Replaceable print heads separate from the ink
You don't want to buy one. $$$. A clogged one can be sometimes restored by soaking in PURE alcohol (99%). Swish it around a bit up and down to help clean the head pores. Dry it off and try in the machine.
black or color printer not printing new inkjet
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Jan 25, 2011 | Brother MFC 210C All-In-One InkJet Printer
I've changed my colour ink cartridge three times now and it still wont print red.
If you allow the red color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Dec 17, 2010 | HP DeskJet 3650 InkJet Printer
Printer will not print
Try taking out your print ctgs and soaking them in some alcohol free glass cleaner for about an hour and when done soaking wipe dry with a paper towel and try to print. Sometimes if inkjet printers sit for a long time without use the ink ctgs will crystallize. You can also clean the encoder strip which is that thin strip of plastic that parallels the bar that the print ctgs ride on, again use alcohol free window cleaner for this, anything other than alcohol free will eat away at the encoder strip. Alcohol sets ink so u shouldn't use it with inkjet printers.
Mar 17, 2009 | Canon Pixma iP4500 InkJet Printer
Brother MFC5840 CN Print heads
Stuts,
I guess you have used generic ink carts.
You should buy an original brother ink cart.
When done so make sure all other carts are at full level:
Press menu then start b/k copy then fourtimes arrow up (tel.index). Machine will be in maintenance mode. press 7 then 6 then 4 then start b/k copy. Machine will refresh ink within tubes and print head and do some power cleaning. when finished press 7 then 6 then 3 then start bk copy to run an extra power purge.
Leave maintenance by pressing 9 then 9.
Do run a quality test print.
If you re lucky the ph will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintnenace mode.
If you like to save money refill ORIGINAL Carts by drilling a 2mm hole into the top (O of brother brandname) . You can leave the hole open to refill the cart next time directly without taking it out of the printer.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of destilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
For bk mix 1 ml glycerin alc with 4ml dest. water and 15 ml bk DYE ink (shake well before refill).
This is -nearly- the exacte mixture of original brother ink.
Mar 02, 2008 | Brother MFC-5840CN All-In-One InkJet...
brother mfc210c
two ways to refill lc41:
drill a 2 mm hole into the brandname (e.g. O of brother ) on top of the cart. You can leave the hole open and leave the carts in the printer in future for further refilling ;-)
The cart can be refilled by inserting a syringe without a needle into the ink Outlet(!) at the bottom, too. Carefully press a 12ml for C/Y/M and ca. 15ml - 18ml for BK into the carts.
Anyway:
Do use DYE-ink only!
Important: You must mix the dye-ink with some 85%-glycerin alc. to keep the print head nozzels alive = 10ml ink with 2ml glycerin alc (drugstore).
For BK: 15ml ink + 1,5ml glycerin alc!
Feb 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
212 people viewed this tip
jasbo
jasbo
