Tip & How-To about Heating & Cooling
How to Replace a Thermocouple on a Water Heater
Thermocouples can be purchased from your local hardware store for less than $20.00. Here is a video demonstrating how to replace the thermocouple. (do not delete)
Heating & Cooling Logo
heater serial # 3687823 was working fine then just stopped. cant get it to light now
if the pilot lights when held but wont stay lit, the thermocouple is shot, local hardware stores sell universal thermocouples. self explanatory to replace. if even when pressing the button the pilot doesn't light there is a blockage in the gas line or control valve. that needs a pro to fix.
Mar 16, 2014 | Procom Heating & Cooling
pilot assembly parts or thermocouples
Hardware store thermocouples don't work on patio heaters. The fittings are not the same thread and they are not set up for the anti tilt safety switch. You'll need to purchase the parts from Blue Rhino.
Jan 29, 2010 | Endless Summer 233000 Open Flame Patio...
I want to know where to buy a thermo coupler for an All Pro SPC 150.
Thermocouples can be purchased at most hardware stores, home depot, etc. The only difference for a thermocouple is the length. There are heavy duty types and regular. I would suggest using a heavy duty thermocouple. Also, it is recommened that thermocouples be changed every 2-3 years to prevent unnecessary failures, which usually occur when you need the unit the most.
Nov 12, 2009 | All-Pro Heating & Cooling
I am looking for a thermocouple for a Charmglow Pure Comfort Solution - Model #CG07010491
Thermocouples are kind of generic. If you remove the one on the heater, you can take it to your local hardware store and match it up. The new ones usually come with adapters for the three main ways they attach. The only thing you really need to make sure of is that is the right length.
Oct 14, 2009 | Williams 2509612 Ceramic Mid-Size Heater
170 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
