Tip & How-To about Computers & Internet
Pc Maintenance(ten tips)
First download your Registry mechanic,full version and make sure you have an updated antivirus on your system.
Secondly, use the registry mechanic to carryout the full registry scan
When u are done,you repair the found files.
After repairing you click on continue then carry out the quick scan.
When u are through,you exit Registry mechanic.Pls be sure to use an antivirus like AVG,ESET NOD,Kaspersky Antivirus softwares and dont forget they must be up to date.
After exiting registry mechanic,go to the start menu,click on the run... button and type 'prefetch' then ok.
When the prefetch window opens,empty the prefetch.
Next,go to you recyle bin and empty it.Exit it and click on its properties to avoid every deleted file from going to the recycle bin.
After all these,go to your desktop background and refresh it.
Thats all for now.I hope these tips will be useful
For more tips pls contact me on this site.I will be willing to assist you.
Computers & Internet Logo
video does play but in few seconds it freezes,so does my computer.
Make sure that you have good Antivirus (like McAfee, Norton Kaspersky etc.) is installed If you want to have a free brand of anti virus software download AVG or Avira. Make sure there updated and scan and clean your PC thoroughly. After that you should have your PC's registry to be in good shape. Obtain "Uni blue registry Booster" ,"Registry Mechanic"or RegCure and scan and clean your registry. If you still have problem with your Media Player remove it and download VLC media play It is the most robust media player I have ever seen. Its free and the best one in the market.
Jul 29, 2010 | Computers & Internet
will not load games
First of all get a good Antivirus software and scan your PC thoroughly after UPDATING it. Updating the Virus software is extremely important.
Secondly after doing the above step install a Registry cleaning software. I recommend Uniblue Registry booster or Regcure. Virus and unclean registry are number 1 reasons to PC slow down.
Check your hard disk if it is near to full. Use the Windows built in disk cleaning software to clean unnecessary files. After that De-fragmenting the disk will also help a lot. To de-fragment a disk Go to accessories in the start menu and then go to system tools. Find disk de-fragmentation and run it the PC performance will dramatically enhance but Virus and registry cleaning is recommended to be done first.
Jul 26, 2010 | HP Computers & Internet
The desktop and the start menu will not appear. I had to use task manager to pull up everything. I have a dell Inspiron 1545
This must be the work of a virus... Please update your antivirus,, and do a complete system scan...
You can also repair your registry files using Registry Mechanic, CleanMyPC registry cleaner etc...
Download here:
http://en.kioskea.net/telecharger/telecharger 1953 registry mechanic
http://www.registry-cleaner.net/
It's probably a win32pirate.b.worm virus, but try the registry cleaner as well
Nov 22, 2009 | Dell Inspiron 1545 Notebook
where can i find good registry cleaner & antivirus
Visit : www.pc-registry-repair.com/
Also for teh antivirus try McAffe its a good & mostly used antivirus software ..
Thanks
Fame !
Apr 29, 2009 | Microsoft Windows Vista Ultimate Edition
how do i get rid of a W32.SillyFDC virus
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
  1. Disable System Restore (Windows Me/XP).
  2. Update the virus definitions.
  3. Run a full system scan.
  4. Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
  • Running LiveUpdate, which is the easiest way to obtain virus definitions.
    If you use Norton AntiVirus 2006, Symantec AntiVirus Corporate Edition 10.0, or newer products, LiveUpdate definitions are updated daily. These products include newer technology.
    If you use Norton AntiVirus 2005, Symantec AntiVirus Corporate Edition 9.0, or earlier products, LiveUpdate definitions are updated weekly. The exception is major outbreaks, when definitions are updated more often.
  • Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them.
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
3. To run a full system scan
  1. Start your Symantec antivirus program and make sure that it is configured to scan all the files.
    For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
    For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
  2. Run a full system scan.
  3. If any files are detected, follow the instructions displayed by your antivirus program.
  4. Delete the autorun.inf file from writeable removable devices, if necessary.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
4. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to the following registry subkeys:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load"
  5. In the right pane, delete any values associated with the worm.
  6. Exit the Registry Editor.
Dec 18, 2008 | Microsoft Computers & Internet
119 people viewed this tip
David Payne
David Payne
