Tip & How-To about Computers & Internet
Short cut keys for pc
Ctrl + A Select all text. Ctrl + C Copy selected item to clipboard. Ctrl + Ins Copy selected item to clipboard Ctrl + V Paste the copied item from clipboard Shift + Ins Paste the copied item from clipboard Ctrl + X Cut selected item. Shift + Del Cut selected item. Windows Explorer: Permanent delete item. Ctrl + F Find. Alt + F File menu options in current program. Alt + E Edit options in current program F1 Universal Help in almost every Windows program. Home Goes to beginning of current line. Ctrl + Home Goes to beginning of document. End Goes to end of current line. Ctrl + End Goes to end of document. Shift + Home Highlights from current position to beginning of line. Shift + End Highlights from current position to end of line. Ctrl + Left arrow Moves one word to the left at a time. Ctrl + Right arrow Moves one word to the right at a time.
Computers & Internet Logo
Meaning of the keys
Shortcut Keys
Description
Alt + F
Alt + E
F1
Ctrl + A
Select all text.
Ctrl + X
Cut selected item.
Shift + Del
Cut selected item.
Ctrl + C
Copy selected item.
Ctrl + Ins
Copy selected item
Ctrl + V
Paste
Shift + Ins
Paste
Home
Ctrl + Home
End
Ctrl + End
Shift + Home
Shift + End
Ctrl + Left arrow
Ctrl + Right arrow
hope this helps
Jun 27, 2012 | ASUS K70IO-A1 (2460556) PC Notebook
Unlock keypad
Create a shortcut
Open the folder or directory that contains the program you wish to create a shortcut for.
Right-click on the program and click Create Shortcut.
This will create a shortcut named "Shortcut to <your program> in the directory you are in. If you wish to rename this shortcut, right-click the file and click rename.
Once the above steps have been completed, you can copy or cut this shortcut and paste it anywhere to execute this program.
Assign shortcut key to that Windows shortcut
Once the shortcut has been created to assign a shortcut key to that Windows shortcut follow the below steps.
Right-click the shortcut and click Properties.
Click the Shortcut tab.
Click in the Shortcut key box and press a letter. For example, if you press "p" the shortcut key will automatically be made Ctrl + Alt + P. Which means if saved when pressing Ctrland Alt and "P" all at the same time will run that shortcut.
Shortcut Keys
Description
Alt + F
Alt + E
F1
Ctrl + A
Select all text.
Ctrl + X
Cut selected item.
Shift + Del
Cut selected item.
Ctrl + C
Copy selected item.
Ctrl + Ins
Copy selected item
Ctrl + V
Paste
Shift + Ins
Paste
Home
Ctrl + Home
End
Ctrl + End
Shift + Home
Shift + End
Ctrl + Left arrow
Ctrl + Right arrow
hope this helps
Jun 04, 2012 | Toshiba NB305-N410BL 10.1 inch Mini...
How do I enter "Favorites" to my keyboard?
im not quite sure i understand do you mean enter favorires FROM or IN or TO my keyboard
thre are no favorites on in or to on your keyboard
can you be bit mores pecific on the problem
Shortcut Keys
Description
Alt + F
Alt + E
F1
Ctrl + A
Select all text.
Ctrl + X
Cut selected item.
Shift + Del
Cut selected item.
Ctrl + C
Copy selected item.
Ctrl + Ins
Copy selected item
Ctrl + V
Paste
Shift + Ins
Paste
Home
Ctrl + Home
End
Ctrl + End
Shift + Home
Shift + End
Ctrl + Left arrow
Ctrl + Right arrow
Nov 14, 2011 | Computers & Internet
what do the buttons on top of the key board mean
Shortcut Keys Description Alt + F File menu options in current program. Alt + E Edit options in current program F1 Universal Help in almost every Windows program. Ctrl + A Select all text. Ctrl + X Cut selected item. Shift + Del Cut selected item. Ctrl + C Copy selected item. Ctrl + Ins Copy selected item Ctrl + V Paste Shift + Ins Paste Home Goes to beginning of current line. Ctrl + Home Goes to beginning of document. End Goes to end of current line. Ctrl + End Goes to end of document. Shift + Home Highlights from current position to beginning of line. Shift + End Highlights from current position to end of line. Ctrl + Left arrow Moves one word to the left at a time. Ctrl + Right arrow Moves one word to the right at a time.
shortcut keys
hope this helps
Sep 30, 2011 | Computers & Internet
letter between c and b wont work! its the paste code key also and I dont recall using it to paste anything Whmat's your problem?
Of course, it wont work because you used a wrong short cut key. The correct short cut command for copying is press the control C simultaneously then for pasting it, it should control V simultaneously. Try it again using the right short cut command. Good luck!
Sep 20, 2011 | Microsoft Comfort Curve 2000 Keyboard
170 people viewed this tip
David Payne
David Payne
