Tip & How-To about Grilling
Gas Grill Won't get as hot as it used to? Read on:
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Grilling Logo
Grill slow to start, doesn't get hot
sometimes spider webs clogs the orifaces. also check your regulator .if its not making any sound give it a light tap with wooden hammer handle sometimes the diaphram sticks
Feb 24, 2012 | Viking VGIQ5323RE1N Gas Grill
Our grill will not light. When the knob is pressed in and turned to 'light' I can see a light inside, but it's like it's not catching and it won't light up. Each burner is doing this. Very frustrating.
It sounds like your grill may have a glo plug type of ignition system if there is a light inside the grill instead of a spark to light each burner. If your grill is hard wired to the house elelctrical, it may be that a breaker is tripped and the power is not getting to the glo plug and the grill us using a battery back up to try and light the grill. The batterys do not last long, and when they get weak, the plug will glow, but not hot enough to light the grill. The other possibility is that you have a short, or some other problem, that is preventing enough voltage to reach the glo plug, the plug will glow, but not hot enough to light the grill.
Jul 03, 2011 | KitchenAid KBNU487TSS Gas All-in-One Grill...
Grill lights but flame is low and goes out if control is moved from high. Burner tube is clean, spider screen is clean, and I have a full tank of LP. Grill is Q series about 1 year old and has been working fine until today.
Mar 22, 2010 | Weber Q Grill
My burners don't put out out much of a flame. Model CGBD48RSBX. Ten years old. Can I clean them?
Hello. Clean them with a wire brush and a shop vac. And, read on: re you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
Mar 21, 2010 | Grilling
Grill wont heat as it did
Mar 19, 2010 | Weber Q Grill
285 people viewed this tip
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
