Tip & How-To about Cell Phones
New secret of iphone
New secret
*3001#12345# and tap Call. Enter field mode
Field mode reveals many of the inner settings of your iphone
specially up-to-date network and cell information
*#06# Displays IMEI. No need to tap call
IMEI is the unique identifier for your cell phone hardware
together with your SIM information it identifies you to the
provider network
*777# and tap Call. Account balance for prepaid iPhone
*225# and tap Call. Bill Balance. (Postpaid only)
*646# and tap Call. Check minutes. (Postpaid only)
These three are pretty self explanatory
*#21# and tap call. Setting interrogation for call forwards.
Discover the settings for your call forwarding. You'll see whether
you have voice, data, fax, sms, sync, async, packet access, and
pad access call forwarding enabled or disabled.
*#30# and tap Call. Calling line presentation check.
This displays whether you have enabled or disabled the presentation
of the calling line, presumably the number of the party placing the call.
*&76# and tap Call. Check whether the connected line presentation is enabled or not.
State whether the connected line presentation is enabled or disabled. Presumably similiar to the calling line presentation.
*#43# and tap Call. Determine if call waiting is enabled
Displays call waiting status for voice, data, fax, sms, sync data, async data,
packet access and pad access. Each item is either enabled or disabled.
*#61# and tap Call. Check the number for unanswered calls.
Sho the number for voice call forwarding when a call is answered. Also show
the options for data, fax, sms, sync, async, packet access and pad access
*#62# and tap Call. Check the number for call forwarding if no service is available.
Just like the previous, except for no-service rather than no-answer situations.
*#67# and tap Call. Check the number for call forwarding when the iPhone is busy.
And again, but for when the iPhone is busy.
*#33# and tap Call. Check for call control bars
thank you
Cell Phones Logo
How to turn of field test mode on my zte z958
Field Test Mode: What it is and How To Enable it on Your Phone
www.ubersignal.com/field-test-mode
  1. Cached
  2. Similar
Most phones have a setting we call Field Test Mode that can show you useful information about your phone, including the signal strength in decibels. ... The iPhone has a hidden built-in Field Test Mode app. .... My Home; My Vehicle; My Work ...
Field Test Mode for iPhone and Android - RepeaterStore
https://www.repeaterstore.com/pages/field-test-mode
  1. Cached
  2. Similar
Your phone can tell you exactly how strong its signal is, in decibels, by entering Field Test Mode. How to enter Field Test Mode varies from phone to phone, but it ...
Finding Your Phone's Signal Strength Reading (Field Test Mode ...
support.weboost.com/.../206521937-Finding-Your-Phone-s-Signal-Strength-Reading-...
  1. Cached
  2. Similar
7 days ago - Finding Your Phone's Signal Strength Reading (Field Test Mode) ... My phone's 3 bars may well represent a stronger signal than your phone's ...
[PDF]Cellular Phone Field Test Modes - wpsantennas.com
www.wpsantennas.com/pdf/testmode/fieldtestmodes.pdf
  1. Cached
  2. Similar
Dial *3001#12345#* and press the Call button. This will launch the Field Test Mode app and where the bars/dots were in the top left corner of the screen, you'll now see "< Back to iPhone". Hold down the power button until you see "Slide to Power Off", then release it. field test mode on my zte z958 Google Search
Dec 13, 2016 | ZTE Cell Phones
How fix lycamobile internet in Samsung Mobile Phone galaxy s 3
hears try this one
Setting up my mobile phone for internet
Want to set up your mobile phone for internet? Follow these easy instructions.
1. Find "Access Point Names"
Tap Apps.
Tap Settings.
Tap More settings.
Tap Mobile networks.
Tap Access Point Names.
2. Create new data connection
Tap the Menu key.
Tap New APN.
3. Enter data connection name
Tap Name.
Key in Optus Yes Internet and tap OK.
4. Enter APN
Tap APN.
Key in yesinternet and tap OK.
An APN (Access Point Name) is used to establish a data connection.
5. Enter country code
Tap MCC.
Key in 505 and tap OK.
6. Enter network code
Tap MNC.
Key in 02 and tap OK.
7. Select authentication type
Tap Authentication type.
Tap PAP.
8. Select APN type
Tap APN type.
Key in default and tap OK.
9. Save and activate data connection
Tap the Menu key.
Tap Save.
Tap the field next to Optus Yes Internet to fill in the field.
10. Exit
Tap the Home key to return to standby mode.
gooluck ^_^
Jul 04, 2014 | Cell Phones
cant get oo computor
Test the Internet Connection
Make sure yourcomputor an Internet connection by opening another Internet application or the app store.
  • If you are not able to reach the Internet through your cellular carrier, try a wireless network.
  • If you are not able to reach the Internet through a wireless network, you may having network connection issues
  1. Check the date and time on your computor
    If the date and time of your device is significantly different from the current date and time, you will have a problem playing your video.
    1. Tap the Settings icon on the Home screen.
    2. Tap General.
    3. Tap Date & Time.
    4. Tap Set Date & Time.
      • If the date and time are incorrect, adjust the time until it matches your time zone.
      • Or, tap On/Off toggle to On in the Set Automatically field.
  2. Reinstall the Netflix application
    1. From the main menu, touch and hold the Netflix app on the Home screen until it jiggles.
    2. Tap the X in the top left of the Netflix icon, then tap Delete.
    3. Enter the App Store, search for "Netflix" and select the free Netflix app from Netflix, Inc.
    4. Tap the Install button. You will need to enter your iTunes password to install the app.
    5. Once installed, tap the Netflix icon.
    6. Enter the email and password for your Netflix account and tap Sign In.
  3. Troubleshoot your Internet Connection
Oct 24, 2013 | Netflix
how to set vpn on ipod 8gb
  • 1 Tap the "Settings" icon.
  • 2 Select the "General" option.
  • 3 Tap the "Network" button.
  • 4 Select the "VPN" option.
  • 5 Select the "Add VPN Configuration" button.
  • 6 Select the tab that corresponds to the type of VPN network you are trying to connect to. You can select "L2TP," "PPTP" and "IPSec."
  • 7 Enter a description of the VPN" in the "Description" field. Enter the IP address of the VPN in the "Server" field and enter your VPN user name in the "Account" field. If you use a password to access the VPN, enter your case-sensitive password in the "Password" field.
  • 8 Tap the "Save" button located in the upper right corner to save your VPN settings.
  • 9 Move the switch located to the right of "VPN" to the "On" position. Your iPod will automatically connect to the VPN network.
  • Mar 29, 2012 | Apple iPod touch
    567 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
