Tip & How-To about Computers & Internet
Usb Boot stick!
Ok... i've been working on this for a while, Finally got it working! First download the program of your choice to put the image file on your flash drive (unetbootin, FlashBoot, Etc...) theres several out there.... Next download the iso of the OS that you want... You can get it from either a download site on the internet, or download a torrent from LimeWire, Use the program to Convert the ISO file to image format and put it on the flash drive, Next put the USB drive in the computer you want to run the OS on, On the Bios screen (boot up screen) press the corresponding button to change the system settings (usually F2) Choose to Boot from the USB drive, Follow the on screen settings and Your done!!!! Good luck and feel free to ask me any questions you have! I would love to Help! UPDATE: If your using a NetBook or other Computer with low memory, You may Have to download a Text Based Instillation Os, Most download sites offer alternative Downloads for these special computers.
Computers & Internet Logo
my harddrive crashed I need free software to recovery photos
there are many freeware and pay data recovery programs available on the web
Try this freeware call smart Data Recovery
http://www.smartpctools.com/recovery/ind...
This is different from other recovery software because it not only recover lost file from harddrive and floppy like most do, but also recover from removable media like flash drive.
http://download.cnet.com/pandora-recovery/3000-2094_4-10694796.html
File recovery has never been easier thanks to Pandora Recovery. The program's wizard-like approach to finding and retrieving lost files will appeal to all users.
http://www.piriform.com/recuva
Accidentally deleted an important file? Lost something important when your computer crashed?
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
hope this helps
Sep 09, 2012 | Dell Computers & Internet
No website connection.applications running slow or not at all.
The question is very vague. Is this a new problem? If it ran OK before, go to Accessories - System Tools - System Restore and pick a date that it worked OK on, the run System Restore.
A free utility "CCleaner" (with two "C"s) can be downloaded from www.download.com . This FREE utility will first clean up your Windows files. Next go the Registry clean up and run the Registry Clean up. You do not need to make any choices in the Registry clean up. Just select to clean up and save a backup. In the Windows clean up you can chose to save or remove the cookies in the options list.
You should also be running a good Anti-Virus program. If not you can download AVG Free from the same place.
This should solve most of your problems. I've lost customers giving this advice as they didn't need to bring in their computers afterwards.
Finally you should De-Fragment you drive(s) to speed up file and program access. To run, go to your My Computer and right click on the hard drive. Select Properties, Tools, Defragment Drive.
There are many other good utilities and anti-virus programs out there. I just suggested a couple of easy to use reliable ones.
Apr 14, 2011 | Motorola Computers & Internet
Upon reccomendation from a Microsoft tech and Acer, I have downloaded the current version of Bios update form my M5641, but have no istructions on how to perform the update. Please help
Ok, you must make a bootable DOS floppy diskette, or a bootable DOS CDrom if the machine has no floppy drive. You can download Windows executable DOS boot disk images here: http:bootdisk.com. I prefer DRDOS 7. There is usually a flashing utility and bios image file that you must copy to the floppy boot disk.
If your not very DOSSY, after the machine boots from the boot disk, you do a DIR, and find the name of the flashing utility. You enter that name at the command prompt: A:/. like this:
A:/flash_utility /h
That will give you help on how to use the utility.
But newer machines have smart bios that only need one file put on the boot disk, and everything is automatic.
Making a bootable CDrom requires special software that you must buy. Or you can use a Knoppix live CD, but you'll need one CD writer and one CDrom. It's ok if both are writers, or even if one is a DVD drive.
Bootdisk.com has bootable CDrom image files. But I only know how to get files inside the image file using Linux. There are programs for Windows that can edit a CD image file. Google 'edit .iso file. And don't pay money. There are good freeware programs. One is called daemontools.
You must copy the bios file(s) to the CD image, and burn the CD. Then boot with it, and do like I described above.
Apr 20, 2010 | Acer Aspire M5641 PC Desktop
Problems when connecting Canon Powershot A70 - Cannot find program to upload pix
The popup would be the windows wizard wanting to assist with downloading image files. There's 2 popups one is the wizard and you'll click on transfer images & it walks you step by step to download the images. The other one is just a one click option & you can copy the images files to your computer. But since those options don't seem to work for you - one solution would be to click on "my computer" and you'll either find your camera or memory card listed along side your computers C drive. If you're downloading images from the camera - it needs to be hooked up via the cable + the camera probably needs to be turned on. Some cameras also have a setting or button to turn in order to download the images.
May 09, 2007 | Canon PowerShot A70 Digital Camera
222 people viewed this tip
David Payne
David Payne
