Tip & How-To about Office Equipment & Supplies
Little Known Facts About Extending The Life of Printer Ink Cartridges.
Did you know that a perfectly good ink cartridge can dry out enough in just two weeks to be no good ever again. Not that all of the ink drys out, just that the ink closest to the working exit drys, clogging the exit holes and preventing the liquid ink from exiting. Often the printer indicates that the cartridge is still close to full but that color will not print out. I recently had this happen with an expensive jumbo black cartridge. After researching this and speaking with two printer technicians, my worst fear was confirmed. My almost new $35.00 ink cartridge was no good. And there is no way to fix it.
Knowing that these cartridges dry out pretty quickly, do not purchase a jumbo cartridge unless you do a lot of printing on a regular basis. The regular cartridges are good for about 200 copies and the jumbo cartridges are good for about 650 copies. If you know you aren't going to use your printer for the next couple of weeks or longer, remove the cartridges and store them.
Follow these steps for the best results:
1. Moisten a cotton ball with a small amount of tap water and carefully clean the residual ink from the working surcface of the cartridge.
2. Use a piece of plastic wrap to cover the working surface of the cartridge.
3. Store the cartridges in a ziplock bag trying to get out as much air as possible. This will prevent the ink from drying and clogging the holes.
I know this seems like a bit of work, but with the cost of these cartridges, it is time well spent. Happy printing everyone!
Km 1620 double side copy makes one side clear and the other side faint
Clean print heads remove ink cartridge and take a paper towel wet it and clean the cartridge off of there is dry ink on it. Your ink cartridge could be almost empty. Ink cartridges dry out fast. If you do not use ur printer often the ink drys out.
Oct 01, 2016 | Office Equipment & Supplies
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
My printer is printing the black text sketchily...some of the text is missing, blurred or too light. My printer is fairly new and has not printed much yet, I don't know if I am getting to the end of my ink cartridge or not.
hi e.... two things.... first of all if that is the original black cartridge it did not come with a full amount of ink. they just give you enough to get started. secondly, if the ink cartridges are not used at least once a week they tend to get dry at the tiny port where the ink comes out and not work as they should. you can remove the cartridge and physically check it for ink left. that is a good starting point. joe
Jun 22, 2011 | Kodak Office Equipment & Supplies
printer not ppinting yellow
The ink drys on the printer nozzle and blocks the ink flow ,remove the ink cartridge, get a syringe with some print head cleaner and pump it into the outlet where the ink cartridge sits let it soak about 1 hour or so , refit cartridge and try again , i just had the black ink block on my R340 took me a day to clear it !
Please you should never let a printer stand without a cartridge in it , print a page once a week to keep the nozzles clear
Nov 10, 2010 | Kodak ESP 5 Printer
CHANGED COLOR CARTRIDGE AS I HAVE MANY TIMES BEFORE. NOT WORKING. MESSAGE IS THAT THIS CARTRIDGE WAS NOT INSTALLED CORRECTLY. HAVE TRIED EVERYTHING - HELP PLEASE ! thanks
good day sir/ma'am, hi, the reason why the printed sends the mesaage "cartridge not installed correctly" mean that it cannot get ink from those cartridges due to dirt and dust, or the ink on the cradle dried out, you may need to clean the cradle, the part were it houses the ink cartridges, since dried ink is solluble to water, use warm water to clean the cartridge. you can remove the cradle or use a dipstick with cloth wrap around and dip it to the dried ink. If the dried ink has soften enough you can place again your cartridge and test print again, do this several times to get the ink flow again. Carefull not to moisten the electronics part of your printer. thats it.
Nov 19, 2009 | HP PSC 950 All-In-One InkJet Printer
261 people viewed this tip
jasbo
jasbo
