Tip & How-To about Office Equipment & Supplies
Why i get black streaks on paper in laser printer prints?
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks .
The window on the canon ir 5055 says the waste toner recepticle is nearly full. Do I need advance notice to order a part once the recepticle is full?
Basicly, the waste toner bottle is emptied out by your service person or if you work on it, then it is you. There is a counter that will display that it is nearly full. The counter will need to be rest and the waste toner has to be looked at and emptied if needs be. The waste toner & the cleaning web have about the same life / couter life. It is not a big deal..... I've never saw a waste toner bottle over file before, but if it is not looked at or checked it may cause some problem. Good Luck
Mar 29, 2011 | Canon imageRUNNER 5570 Copier
Streaking on left side of page
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | HP LaserJet 1200 Printer
on bro copier mfc 3240c printer will not copy with only black ink full and magenta empty and others near empty. will copier not wk if all are not replaced when empty or near empty???
check with brothers tech support to see if you can set the machine to use black toner only... if not then you have to replenish all the empty or near empty toner cartridges...
Dec 18, 2009 | Office Equipment & Supplies
Toner level
To check the toner level, there is a little clear window on each cartridge you can use for this purpose. Hold the cartridge vertically. If you see toner in the window, it is more than half full (or less than half empty, ha!). If not, slowly tilt the cartridge toward the side with the window. Essentially, how far you tilt it before you see toner determines how far below half full it is. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option).
If you do have to replace or refill, don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, the waste toner bottle will likely be nearing capacity.
Jun 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Waste toner near full?
You can empty the waste chamber on the image unit by removing the screw from both ends of the unit, pull the ends off and empty it out. It's a messy job so have a good plastic bag and a toner vacuum if possible. The message might stay on awhile but will disappear with time. The alternative is a new image unit.$$$$$$
Apr 14, 2009 | Office Equipment & Supplies
470 people viewed this tip
jasbo
jasbo
