Tip & How-To about Washing Machines
The washing machine will not spin?
There are many possibilities for this problem, but the most common and regular problem seen is as follows:--
There is a lid switch in the washer. The washing machine will not start spinning till the lid is closed. In some cases it has been seen that lid is closed still the washer does not spin. in this cases the lid switch has to be checked. if the lid switch is faulty then the closed lid will not be detected by the washing machine, and it will not start spin cycle.
This will help. Thanks.
Washing Machines Logo
doesn't start the spin cycle
First of all check if the motor is running or not when you turn on the motor. If the motor is not turning on then this problem is due to fault in the motor. But if the motor is getting on and running properly then most probably this problem relates to stuck up or cracked drain pump pulley. It needs to be checked but if the pump pulley is functioning properly then check the drain pump belt. If the drain pump belt is worn out or loose or cracked/broken then it needs to replace. But if the motor is not running then before replacing the motor check the lid switch.There are many possibilities for this problem, but the most common and regular problem seen is as follows:--
This will help. please keep updated for any further assistance if more help required.Thanks.
Apr 29, 2010 | Hotpoint Washing Machines
Kenmore 500 top load washer starts to fill withwater then stops
This is commonly caused by a lid switch malfunction. If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
If the lid switch is found to be defective, it can be purchased at any of the following websites:
searspartsdirect.com
applaincepartspros.com
pcappliancerepair.com
repairclinic.com
The average price is $25 to $35. Prices vary between these sites, so shop around for the best deal.
This is a very simple repair, but if you still have questions, please let me know. I hope this helps you.
Oct 06, 2009 | Kenmore 24032\24036 Top Load Washer
My machine quit running part way through the cycle...
This problem is commonly caused by a lid switch malfunction. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, I would recommend you check your lid switch first. Due to the amount of wear it is the most common cause of these symptoms and least expensive to repair.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
NOTE: On this type of lid switch the lig hinge has a small rod that is used as an acutator to toggle the switch. In many cases, you can adjust the rod by bending it if the switch is not making contact.
If you determine the switch to be defective, the following link explains how to replace one:
If parts are needed, a replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
If you have questions, please post back with your complete model number (located along the wash tub rim under the lid), so that I may be able to provide you with better assistance. I hope this hel.ps you
Sep 22, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
fisher and paykel dd-603ss
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios; 1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models) 2. Something too tall was placed in the drawer preventing the lid from closing completely. OR 3. (only seen this once) the drain hose developed a crack causing water to leak only when draining. Hope this helps....
Jun 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
160 people viewed this tip
Top Washing Machines Experts
