Tip & How-To about Computers & Internet
Keyword blocking and parental control features on NETGEAR routers
The below steps illustrates the required troubleshooting procedure to configure keyword blocking and parental control features on NETGEAR routers.
Applicable routers are WGR614, WPN824, WGT624, WNR2000, WNR1000, WNDR3300, WNR854T, WNR834B etc:
Login to the router page using the below steps:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
-In the routers configuration page, under the Content Filtering Section
- Select Key Word Blocking
Key Word Blocking is:
If you want to limit access to certain sites on the Internet, you need to set up content filtering. There are two ways to filter content:
* blocking access to certain domains (for example, www.badstuff.com/XXX) or
* blocking sites that contains certain words (like profanity or explicit sexual material).
When users try to access a blocked site, they will get a message: "Blocked by NETGEAR".
-To Enable Site Blocking:
Click Per Schedule to turn on Site Blocking and block according to the settings on the Schedule page.
Click Always to turn on Site Blocking to allow blocking all of the time, independent of the Schedule page.
Note: On the Schedule page you can set when keyword and domain name blocking occurs.
To Disable Site Blocking:
Click Never to turn off Site Blocking.
-To Block Keywords Or Internet Domains:
1. Select when to turn on Keyword Blocking (Never, Per Schedule, or Always).
2. In the box where you see Type Keyword Or Domain Name Here, type the word or domain name you want to block.
3. Click Add Keyword.
4. The word or domain name will appear in the list below.
5. Continue adding names and keywords until you are finished.
6. Click Apply when finished.
Block List - The list under the heading "Block Sites Containing these Keywords or Domain Names" contains the current list of items to block.
To Delete A Keyword Or Domain Name:
1. Select the word or domain name in the list.
2. Click Delete Keyword.
3. Continue selecting and deleting names and keywords until you are finished.
4. Click Apply.
To Delete All Keywords And Domain Names:
1. Click Clear List.
2. Click Apply.
To Allow One Computer To Have Unrestricted Access To The Internet:
1. Select the Allow Trusted IP Address To Visit Blocked Sites check box.
2. Type the IP address of the computer in the Trusted IP Address area.
You should only need to type a number in the last box.
3. Click Apply.
To Allow Unrestricted Access To The Internet:
1. Select Never in the Keyword Blocking menu.
2. Click Apply.
Computers & Internet Logo
facebook how to block
Select Turn Parental Control OFF, Turn Parental
Control ON and ALLOW computers access to
ONLY these sites, or Turn Parental Control ON
and DENY computers access to ONLY these
sites.
Enter the keywords or URLs that you want to
block (or allow). Any URL with the keyword (facebook) in
it will be blocked.
The schedule of time when the parental control
filter will be enabled. The schedule may be set
to Always, which will allow the particular service
to always be enabled. You can create your
own times in the Maintenance > Schedules
section.
Nov 28, 2013 | D-Link DIR-600 Router
reset
You can reset your Netgear router/wireless wpn824 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless wpn824 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear wpn824 router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the wpn824 router has been reset.
Feel free to get instant online Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Dec 15, 2007 | NetGear RangeMax WPN824 Router
parental control
The following types of parental control can be configured on the VDI-604/VDI-624: Domain Blocking URL Blocking -------------------------------------------------------------------------------- Domain Blocking Domain Blocking will allow/deny access to certain websites. Step 1 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 3 Click the Advanced tab at the top and then click Parental Control on the left. Step 4 Below Parental Filters, select Domain Blocking. Step 5 Below Domain Blocking, select Allow users to access all domains except "Blocked Domains" to only allow to all websites except those listed or select Deny users to access all domains except "Permitted Domains" to only allow access to the websites listed. Step 6 Enter the website (i.e. disney.com) below the option you selected in Step 5 and then click Apply. -------------------------------------------------------------------------------- URL Blocking URL Blocking will prohibit access to websites than contain certain words. Step 1 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 3 Click the Advanced tab at the top and then click Parental Control on the left. Step 4 Below Parental Filters, select URL Blocking. Step 5 Below URL Blocking, select Enabled, enter the word, and then click Apply.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
2,116 people viewed this tip
David Payne
David Payne
