Tip & How-To about Washing Machines
The washing machine spins but will not drain?
To trouble shoot this problem please check this possibilities:-- The first thing to check out in this problem is check the draining line in the washing machine. Check if the drain line is got clogged or its getting blocked by any metal or dust object in the pump. Also check in between the inner clothes tub and the outer tub which holds the water. If the blockage is between the tubs, then it may clog the drain hose which is connected to the pump. If you notice blockage in the pump, then remove the hoses from the pump and clear the blocking material by removing it out.
But if the pump is clean and clear and hoses are also seen clean then the other part to check is
outer tub part, for that you will need to open the washer's main access panel and remove the rubber material hose connecting the pump .the hose is exactly connected to the bottom area of the outer tub. If you notice any blockage/clogging in that area you can remove it with the help of pliers.
If you are not able to remove the clog or if you can see but its seen in very inner area then you need to take the agitator out, after removing the agitator remove the top of the outer drum shield, and inner clothes tub. You will require some special tools to do the job in this case.
But if inner tub, agitator and other parts looks clean and clear then you need to check the drain pump. it may be leaking or it may be worn out and got loose.
This is the basic checking and troubleshooting you can do it yourself to resolve this issue of not draining.
Washing Machines Logo
my dishwasher is leaving a soap residue after the wash cycle. What do I need to do?
Many possible causes.
My list to trouble-shoot this would be:
  1. Rinse dishes less before loading--the dirt on the dishes is what the detergent acts upon. You only need to rinse off hard stuff like bones, seeds, toothpicks, and so on.
  2. Is your rinse-aid dispenser putting out enough?
  3. Use a little bit less detergent.
  4. Check the little nozzles in your spray arms. Maybe they have become blocked. (Sesame seeds are the sort of thing that cause headaches here.)
  5. Check drain lines and filters.
  6. Do you have hard water? Maybe your machine would work better with a water softener--whether built into the machine, or on the supply lines for the house.
Feb 20, 2011 | Bosch SHE45M06UC Built-in Dishwasher
Why are dishes not getting the soap rinsed off efficiently? Heavy soap residue remains even with rinse treatment.
Feb 20, 2011 | Frigidaire Dishwashers
how do istop the tcl portable air con leaking water
As you probably know, Air conditioners condense the moisture out of the occupied space, as the room air passes over the colder coils.
That water has to drain away into a drain, or a bucket -- or something!
So-- How is the water designed to drain away?
and what is interfering with that path?
There are the obvious causes, like mold, or a bug, or dirt, etc-- blocking the drain hole-
Or possibly sediment filing the condensate line trap--
Are you sure these are all clear, and open?
But one that is often overlooked, is the fact that a fan might be creating a slight vacuum in the area where the drain line exits the rain pan--- and the water can actually be prevented from draining, until the fan shuts off (removing the slight vacuum)-- is that possible in this machine?
Or when you open up the machine, is the drain pan still filled to over flowing?
Can you use a mini Toilet plunger on the drain, to help unblock it?
Give me some more clues, and I'll try to help you trouble shoot deeper into the problem.
Mack B
Jan 16, 2011 | Heating & Cooling
my son's ipod touch wont turn on at all, sometimes we get a battery with a red line and then it goes off, even if we connect to the computer, help
The link below will bring you to the iPod Touch: hardware trouble shooting page. This page will contain all the information required to trouble shoot your problem.
http://support.apple.com/kb/ts2771
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 03, 2010 | Apple iPod touch
what
The drain that runs the condensation from the unit is plugged or trapped...the condensation then blows out the front...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 19, 2010 | LG Heating & Cooling
176 people viewed this tip
Top Washing Machines Experts
