Tip & How-To about Audio Players & Recorders
Harmony remote always sets TV to channel 3
So I have had this a few times where the setup wizard for the Watch TV Activity not only asks what input the TV has to be on, but also what channel. A lot of the time I got annoyed when the channel would always goe to a particular one (usually 3) at the beginning of the Activity.
Unfortunately, we can not get rid of this setting, although there is a workaround. If we go through the setup for the Activity again, and select the channel to be '0' for the Activity, in most cases that will work.
When most TV's receive a '0' channel command and no other numbers, it disregards the command and stays where it is.
Hope it helps
I have harmonyH659, I am getting Cable when I push 'watch tv button'. But when I push 'more activities", I amnot getting my dish connection. Used to be OK for last 3 years. what do I do?
Changing the Input settings within an Activity:
1. Login to your Harmony Remote Account.
2. Click on the Settings button next the Activities you are having issues with.
3. Choose Review the settings for this Activity.
4. When the software asks What input does the TV need to be on, change these to the correct settings.
5. Continue through the setup until you are brought back to the Home Screen.
6. Click on the Update remote button and follow the on screen steps.
7. Once the update is completed, please test the Watch TV Activity.
Jan 25, 2010 | Logitech HARMONY 659 Remote Control
I am housesitting for someone who has the harmony 550 and I have lost the sound... can anyone walk me through this?
Changing the settings within an Activity:
2. Click on the Settings button next the Watch TV Activity.
4. When the software asks What input does the AV Receiver need to be on, please choose the Input that you herd sound coming from when doing the testing.
Jan 22, 2010 | Logitech Harmony 550 LCD Remote Control
need to reprogram for new amplifier
Add the new amp to the harmony account.
replace the old amp with the new amp in every activity:
then delete the old amp from your acocunt by clicking on the trash can next to the old amp. confirm the deletion and click next.
then update your remote.
Jan 19, 2010 | Logitech Harmony One Advanced Universal...
everything works except no picture of tv
The Television may be out of synchronization with your remote or may be configured incorrectly.
1. In front of your Television, press the Help button on your Harmony Remote.
2. Answer No when asked "Did that fix the problem?"
3. The Harmony will then ask, one by one, if all of your required devices powered on when the Activity was started. Answer Yes or No until all required devices are powered on.
4. Answer No if the remote asks if the TV is set to the correct input needed for the Activity. In this example Input 4 is used, though this may vary from your setup. If the TV switches to another input but no picture is seen, continue answering No until an image appears.
5. If you now have a picture on your TV screen, answer Yes when asked if the problem is now fixed. Your television was simply out of synchronization with your Harmony One and should now work correctly. Please try switching between your other Activities to see if they switch correctly. If this has not fixed the problem, proceed to the next section Confirming your Activity Settings.
To confirm your Activity Settings, please follow the steps below:
1. Launch the Logitech Harmony Remote software and login to your account.
2. Click on the Activities tab on your home page
3. Click on the Settings button for the Activity you wish to troubleshoot.
4. Select Review the settings for this Activity and click on the Next button.
5. Confirm the input chosen for your television is correct. Select No, I want to run the setup wizard again to change these settings and click on the Next button.
6. Click on the Next button through the Activity setup screens until you arrive at the screen asking the question "What input or channel does your ... TV need to be on? From the list, select the input that the TV uses for this Activity. Once finished, click on the Next button.
**NOTE: It is recommended to perform these steps for all Activities that use the television.
8. Click on the Done button on the Set Up Activities: Summary page.
9. Click on the Done button on the "Select the Activity settings you would like to modify" screen.
10. When you have finished, click Done to save your changes.
11. Click on the Update Remote button to update your remote.
Jan 17, 2010 | Logitech Harmony 966208 Remote Control
I have a Logitech Harmony 670 remote. The problem I am having is when I want to use the "Watch a DVD" activity, there is no audio. I have audio on all other activities. (I have surround sound). I have tried the remedy described in the "Sound Mode" of the instruction manual. Still no audio. My e-mail address is: bwj333@netzero.com
Oct 29, 2009 | Logitech Harmony 670 LCD Remote Control
152 people viewed this tip
 Grubhead
Grubhead
