Tip & How-To about Computers & Internet
Upgrade firmware on NETGEAR router. Many a times, it is required that you upgrade the firmware on your NETGEAR for it to function properly and be equipped with the latest updates and feature offered by NETGEAR. I have listed the specific steps which are required to upgrade firmware on most of the NETGEAR A. Open the router page using the following way: 1. Connect a computer to the router using any one of the 4 available ports. 2. Open the browser(Internet Explorer or Mozilla Firefox). 3. Access the router, usually with http://192.168.1.1 or http://192.168.0.1 or http://www.routerlogin.com. 4. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive. In case you have changed the password for router login then you need to use that one). B. Visit the following link to download the latest firmware. http://kb.netgear.com/app/ Type the model make of your NETGEAR router and it will show you the download page for that specific product. C. Please follow the steps to upload the firmware of the router: 1. Open the router page using the steps as mentioned under step A. 2. Under Maintenance, click router Upgrade. 3. Click Browse and locate the upgrade file. 4. Click Upload. 5. Wait for the router to reboot. 6. Click on 'Logout' (at the bottom of the list) from left menu. It is recommended that you reset and then reconfigure your router for the firmware to upload properly. NOTE: Please upgrade the firmware on a computer connected wired to your router. Upgrading firmware on a wireless computer may cause your router to malfunction and can lead your router to be in an unusable state. These steps will succesfully allow you to upgrade firmware on your NETGEAR router.
Computers & Internet Logo
firmware version
Wireless routers contain built-in programmable logic called firmware. The firmware is embedded software that implements network and security protocols for that specific model of hardware device.Every wireless router ships with a tested version of firmware provided by the manufacturer. However, most routers are also designed to support a firmware upgrade process. This allows the manufacturer to provide enhancements to routers already sold. Manufacturers generally provide firmware upgrades as free downloads from their Web site.
Additionally, a few manufacturers (like Linksys) provide their firmware as open source code on the Internet. Programmers worldwide are free to modify and extend the code with new features for their routers. Several versions of this hacked firmware can be found on the Web, but the average homeowner should avoid these types of firmware.
The Firmware Update Process
You begin a firmware upgrade by downloading a binary file package from the manufacturer's Web site. After the package is set up properly on a PC, an administrator can launch the actual upgrade from the wireless router's administrative console. The router will stop functioning if the upgrade fails to complete. For this reason, manufacturers generally recommend an Ethernet cable be run from the router to the PC to ensure maximum stability during the update. Consult the router's product documentation for details.
Immediately after purchasing a router, check the firmware version to ensure it is the latest version. Firmware can be installed on a router at the factory several months before the router is sold.
Then, check the manufacturer's Web site occasionally over time for any new firmware upgrade postings. Each time a firmware upgrade is posted, the manufacturer will provide notes detailing the enhancements it provides. Feel free to skip an upgrade if the new version does not offer any interesting features. However, if a router is performing sluggishly, freezing unexpectedly or experiencing dropped connections, firmware upgrade often supplies a quick fix.
Dec 15, 2011 | NetGear Computers & Internet
I tried a firmware upgrade to resolve an issue with the router dropping WiFi connections but now it doesn't work even after a factory reset
Wrong firmware. Never upgrade firmware unless recomended by the mfgr or the unit itself can upgrade automatically like most newer Netgear models.
Buy a new router, they are very inexpensive.
Sep 12, 2011 | NetGear DG834G Router
My ZyXEL p660 router after being reset will not power up properly anymore the power led flashes green and the wireless light stays on after about 15 seconds the powers led stops flashing and turn off aswell as the wireless's led
You will find ADMINISTRATION tab in the upper right hand corner.
click on the administration tab. just below the administration tab you will find firmware upgrade sub tab. Click on Firmware upgrade.
Now on this window you will find browse option. click on the browse button and select the firmware file that you have downloaded on the computer. after selecting the proper file click Upgrade. The upgrade process will start.
It may take 2 to 5 minutes.
once you upgrade the firmware of the router, unplug the power cable of the router , wait for 5 seconds and plug it back in.
For Netgear router
# Click Maintenance > Router Upgrade
# Click Browse and find the file you just downloaded.
# Click Upload. Do not interrupt the upgrade while the router does this step.
For Belkin router
Open a web browser on the computer.
In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
Click Login in the upper right-hand corner of the page.
The router does not ship with a password, so just click Submit.
Click on "Firmware Update" toward the bottom of the left-hand menu.
For D-link Router
Open the web interface of the router.
Go to TOOLS
Under tools you will find FIRMWARE.
Jan 19, 2011 | Computers & Internet
NetGear RangeMax WPN824 Wireless Router (WPN824NAR) Wireless connection drops in and out regularly but frequency of this is unpredictable duration is usually a few seconds. Works find on direct ethernet connection.
Upgrade the Firmware of the router :
First you should check the version of you WPN824 (v1,v2 or v3). If there are no Version after the model number, it should be a version 1. Download the Firmware of your router given the correct version at this link :
http://kbserver.netgear.com/products/WPN824.asp
This is assuming that other wireless laptops has the same problem onyour wireless router. If other Laptops works great on your wirelessrouter without dropping any wireless connection, then you shouldconsider upgrading the wireless adapter on you own laptop.
***(If you haven't tried connecting otherwireless laptop wirelessly to the netgear, then you should try it firstto be sure that the netgear is the problem)
Steps on how to upgrade Netgear firmware :
  1. Download the correct file depending on your location and unzip the file to a convenient place such as your desktop.
  2. Log in the router at http://192.168.1.1 or http://192.168.0.1 (or www.routerlogin.net ) (Which ever will work)
  3. Default User name : admin / password : password
  4. Click Maintenance > Router Upgrade.
  5. Click Browse and locate the file you just downloaded.
  6. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
***Therouter reboots when the upgrade is complete.
***Tocheck that the upgrade was successful, log in to the router again at http://192.168.1.1and check the firmware version.
***DONOT UPGRADE FIRMWARE USING A WIRELESS LAPTOP/PC
Oct 26, 2008 | Computers & Internet
Siemens SpeedStream 2614 Router
Updates for this model were probably discontinued some time ago. For basic routing functions, you don't really need to upgrade. If you want this router to provide some basic firewall functions to protect against hackers on the Internet, it would be best to upgrade to one of the inexpensive LinkSys, Netgear, or D-Link routers that have improved firewall capability.
Jan 05, 2008 | Siemens SpeedStream 2614 Router (ss2614)
244 people viewed this tip
David Payne
David Payne
