Tip & How-To about Computers & Internet
What to do when the computer powers up - but the screen stays blank
Follow these methods, each one at a time, to fix your problem:
A) Unplug the power cord from the computer. Press the power button of the computer (yes, without any electricity source connected!) several times; Reconnect the cable and power-up normally.
B) Double-check to see if ALL the rear connections are firmly connected.
C) Test your monitor with a different computer, to see if it works well.
Alternately, try a different monitor with your own computer to see if the problem persists. Also, try using other VGA or DVI cable (the cable that connects the computer with the monitor).
D) Open the computer case and look for any blown capacitors (these are electrical tube-shaped component. When they're blown/damaged their top is NOT flat), especially around the CPU area. If you find any - Your motherboard's DEAD. Sorry. It needs to be replaced! If you don't find any - proceed...
E) Clean dirt and dust! Pay special attention to the CPU heatsink and it's fan.
F) Remove, clean and restore the memory (RAM) modules (a rectangle electronic circuit, containing lots of chips on it; Usually placed to the right on the CPU) and the graphic adapter (if it's an extension card). Try using different slots for the memory modules, if there are any.
G) Replace/test another power supply (looks like big metal box with lots of power cords connected to it).
H) Replace/test with other memory modules. Make sure they fit your computer configurations, in terms of speed (Mhz) and size (GB/MB).
I) Replace/test with other graphic adapter:
* Remove the graphic card and use the onborad adapter, if there's any.
* Remove the graphic card and use other one.
If none of the above worked for you - your motherboard probably faulty. In that case, you'll have to have it replaced. It can also be a problem with the CPU itself - but this is very uncommon.
GOOD LUCK!
Clarification: These tips are for when NOTHING is shown on the screen at all ("No Signal" messages considered as "nothing" in that matter)! If you do see something on your screen, the analysis and the solution might be different!
Computers & Internet Logo
Error code E27, ink absorber is full. Call service.
Follow these steps :
1. Unplug the power cord
2. Press and hold down the Stop / Reset.
3. Insert the power cable
4. Press and hold down the power button (the button Stop / Reset fixed in press)
5. When pressing the Power button, then release the button Stop / Reset.
6. Press the Stop / Reset 2 times then release the Power button.
"Wait until the digit 0 appears in the display"
7. Press the Stop / Reset 1 time.
8. Press the Power button 1 time, the printer will print a sheet of paper.
9. Press the Stop / Reset 2 times.
10. Press the Power button 1 time, the printer will mecetak a sheet of paper
11. Press the Stop / Reset 3 times.
12. Press the Power button 1 time. (No printing)
13. Press the Stop / Reset 4 times
14. Press the Power button 1 time rather long and loose (to turn off the printers).
"If the printer still can not get turned off, unplug the printer power."
15. Turn on the printer.
16. E27 error message is gone & the printer is running normally.
Oct 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hi, How do you change the time on a Panasonic KX-T7633 CORDED PHONE
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Oct 19, 2009 | Panasonic KX-T7633 Corded Phone
The green power light on my Canon BJC80 flashes and will not stop. I have not used it in MONTHS so clearly the ink cartridge is dry. Is there any link to the flashing light and the out of ink status?
try this
Indicates Waste Ink Full error
To repair follow the steps below
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Jun 26, 2009 | Canon BJC 80 InkJet Printer
my canon bjc 80 wont print and error light continually flashing
6: Press POWER
9: Press RESUME
Mar 28, 2009 | Canon BJC 80 InkJet Printer
system turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
2,353 people viewed this tip
David Payne
David Payne
