Tip & How-To about HTC Hero Smartphone
Turn Off Sense on HTC Sprint Hero
For those of you who may not like all of the fluff and frills of HTC's Sense (think of it like a theme that sits on top of Android), you can easily turn it off and use the standard Android user interface.
Possible drawbacks? Nothing that will affect the functionality of the phone. You will get fewer home screens (down to 3 instead of 7). You also lose the use of HTC widgets.
  1. Press MENU button.
  2. Go to Settings > Applications > Manage Applications.
  3. Wait for the list of Apps to appear.
  4. Scroll down until you see HTC Sense and select it.
  5. Press the Clear Defaults button.
  6. Press the HOME button. You will be prompted to select which app to compete the action with. Select Home.
You can choose to make it the default if you want to go the stock Android every time you hit the HOME button. But if you just want to play with it to see if you like it better, leave the Defaults box unchecked. Just keep in mind that every time you hit HOME, it will ask you if you want to use Sense or Android Regular until you select one of those to be the default.
This method may also work for other HTC phones that use the Sense interface.
HTC Hero Smartphone Logo
HTC Wildfire Sense not responding
I have a few questions hopefully i can help if you are still having this problem. What version of Android are you running? Are you running a task manager app if so uninstall it? Try wiping the data in HTC Sense by going ini your phones settings then go to apps then select the all tab. Go down the list until you see HTC Sense. Hit Force Stop and then clear data. Hopefully this helps. Another recommendation is an alternative launcher from the Play Store such as ADW EX or Apex Launcher. Hopefully this helps. The old HTC Sense is a resource hog and replacing the launcher will improve performance. An even bigger step would be to root the device and remove sense all together. Let me know if you need help with this.
Nov 29, 2012 | HTC Wildfire Cell Phone
how to change operating system to android
Unline the iOS apple provides, there are many different styles of the Android OS. Think of your phone like a car, android makes all the engines, but HTC, samsung, ect, get to the design the body!. Your HTC F3 will be loaded with HTC sense, which is a great android powered operating system. Cheers!
May 06, 2011 | HTC F3188 Smartphone
how can I install Android 2.2 in my HD2,thanks.
Prerequisite to run Android 2.2 Froyo on HTC HD2
1. Flash HardSPL3 on HTC HD2
2. Flash any HTC HD2 Radio ROM Leo_RADIO 2.08 onward
Guide to install and run mattc Leo + Froyo w/Sense 1.7 build
1. Download zip file here.
2. Extract contents of zip file to your SD card. Note - Android folder should be located at root level (SD card\Android).
3. Using file explorer in Windows Mobile, inside the 'Android' folder run CLRCAD.exe (to fix audio issue). Don't worry, it will appear to do nothing, that is normal.
4. Run Haret.exe.
5. Enjoy...
Note - Android 2.2 Froyo on HTC HD2 is not perfect yet compare the actual Android phone HTC Desire. Some functions are not working. And I got white and black screen of death (SOD) sometimes. But it is getting better and better each day. Hoping it will out perform actual Android phone out there soon.
Mar 04, 2011 | HTC HD2 Smartphone
I want to download a FREE htc desire theme. And i woyld like it even better if the theme lookt like a iphone theme does
Best if you use your wireless connection as the data will transfer faster when you do this. ( I'll assume you don't know how to do this as too much info is better than not enough)
To do this press -
1 menu
2 All Apps
3 Settings
4 Wireless and Networks
5 Turn on Wi-Fi
If you don't have Wi-Fi connection follow same steps but turn on Mobile Network instead of Wi-Fi
Then back up to the home screen
Select
1 menu
2 All apps
3 Market
This will take you to the android market where you can dowload loads of apps, for free or some you have to pay for.
When you are in the market select the magnifying glass in the top right hand corner of the screen then type in "themes" or more specifically "i phone themes" and you will get loads to choose from, if you cant find the one you want for free the usual price I saw for them was about £0.63, depends how bad you want the theme.
Nov 30, 2010 | HTC Desire Cell Phone
how to install .theme file on HTC P3400i...not da .tsk file ok...
copy the theme file to windows folder in the device. go to today settings and choose the theme
Jul 09, 2009 | HTC Touch P3450 Smartphone
1,001 people viewed this tip
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
