Tip & How-To about Cell Phones
How to disable a STOLEN mobile phone?
To check your Mobile phone’s serial number, key in the following digits on your phone:
* # 0 6 #
A 15 digit code will appear on the screen. This number is unique to your handset. Write it down and keep it somewhere safe. when your phone get stolen, you can phone your service provider and give them this code. They will then be able to block your handset so even if the thief changes the SIM card, your phone will be totally useless.
You probably won’t get your phone back, but at least you know that whoever stole it can’t use/sell it either.
Cell Phones Logo
where do i find the serial number on my samsung rogue? I see a Model number , a SKU number , a FCC ID number , and a MEID HEX number
Improve the Fixya.com experience for everyone by voting!
The serial number you're seeing, you have already found. Model numbers, SKU numbers and FCC numbers are there for a variety of purposes. The only number for you to concern yourself with is the substitute for the serial number.
MEI (International Mobile Equipment Identity) numbers are used to help mobile phone companies and you keep track of mobile phone usage. If your phone is lost or stolen, the phone company can enter the IMEI number into the database and permanently deactivate the phone. Even if the SIM card is changed, the mobile phone will not work. There are a few things you can do to find the IMEI number on a mobile phone. Obviously, you've already discovered it so you may find the rest of this boring. In any event, you can be a hero to any friends who might encounter the same problem. Just don't tell them that you got the information free on the Internet.
Difficulty:
Moderate
Instructions
Things You'll Need
Mobile phone
1. Open the battery cover on your mobile phone and remove the battery. The IMEI number should be located on the white label under the battery. It will be 15 to 17 digits long with no letters or slashes. You only need the first 15 numbers.
2. Replace the battery and power the phone on. If the IMEI number is not located under the battery, there are other ways to find it. Wait for the phone to initialize before continuing.
3. Enter *#06# on your phone's key pad. When the final # is entered, a 15-digit number with the title "IMEI number" will appear. Copy the number down and keep it for future reference.
4. If that didn't work you have still more options. If your phone is made by Motorola, you need to press #,*, (menu) and then press the right arrow very quickly. Do not pause when pressing the keys. The IMEI number will appear on the screen.
5. Check the phone's menu if you have a SIM card. Scroll through the menu until you find IMEI or SIM ID. Press enter to display the phone's IMEI number.
6. If you have an older phone with a SIM card, you can press the right arrow until you see IMEI. Press the Enter key to see the IMEI number. If there are only seven digits shown, you can hit the Menu key and then the Next key to see the remaining digits.
Tips & Warnings
Write down your IMEI code so you have it in case your phone is lost or stolen.
  • Report your phone lost or stolen immediately and give the phone company your IMEI number so they can disable your phone.
  • The IMEI number retrieval code (*#06#) does not work for all phones.
See that wasn't too bad.
All the best,
Ben
Jul 15, 2011 | Cell Phones
DO THIS IF YOUR MOBILE PHONE IS STOLLEN
you may contact the service provider......
Apr 06, 2010 | Cell Phones
wheres serial number on phone
First make sure you cell phone is fully charged.
Input these digits in order on your keypad:
0
6
See if anything happens. If nothing does you may have to press send after pushing the last # button. Look for the number that appears on your cell phone screen. This fifteen digit code represents the serial number of your phone.
I would write this down and save it for whatever you need.
Jun 13, 2011 | Cell Phones
what is imei
The IMEI (International Mobile Equipment Identity) is a unique 17 or 15 digit code used to identify an individual mobile station to a GSM or UMTS network. The IMEI number provides an important function; it uniquely identifies a specific mobile phone being used on a mobile network. The IMEI is a useful tool to prevent a stolen handset from accessing a network and being used to place calls. Mobile phone owners who have their phones stolen can contact their mobile network provider and ask them disable a phone using its IMEI number. With an IMEI number, the phone can be blocked from the network quickly and easily.
It is important to note that swapping a SIM card will not stop a phone from being banned. IMEI numbers are stored in the phones themselves, not on the SIM cards.
An IMEI is only used to identify the device and does not relate to a specific individual or organization. Other numbers such as the ESN (Electronic Serial Numbers) and MEID (Mobile Equipment Identifiers) can link an individual to a phone. Usually, an IMSI number stored on a SIM card can identify the subscriber on a network.
There are several ways in which you can locate your mobile phone's IMEI number. The IMEI can usually be found on the handset, beneath the battery, sometimes printed on a small white label. Another way to easily locate your IMEI phone is to dial the following sequence of numbers into the handset: *#06#. If you have a Sony Ericsson mobile phone, you can retrieve the IMEI by pressing the following key sequence: right,*, left, left,*, left, *, left.
The Structure of an IMEI Number
IMEI numbers either come in a 17 digit or 15 digit sequences of numbers. The IMEI format currently utilized is AA-BBBBBB-CCCCCC-D:
  • AA: These two digits are for the Reporting Body Identifier, indicating the GSMA approved group that allocated the TAC (Type Allocation Code).
  • BBBBBB: The remainder of the TAC
  • CCCCCC: Serial sequence of the Model
  • D: Luhn check digit of the entire model or 0 (This is an algorithm that validates the ID number)
Jan 06, 2011 | Motorola Mobility RAZR V3
what is imei number?
The International Mobile Equipment Identity or IMEI (pronounced /aɪˈmiː/) is a number unique to every GSM and WCDMA and iDEN mobile phone, as well as some satellite phones. It is usually found printed inside the battery compartment of the phone. It can also be displayed on the screen of the phone by entering *#06# into the keypad.
May 29, 2009 | Nokia 1100
269 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
