Tip & How-To about Sport & Outdoor - Others
How to see clearly through an iced up windscreen
If your car has stood out in winter overnight then the windscreen is bound to be frosted up with a thick layer of solid semi-opaque ice. If you attemp to scrape it off you will damage the soft laminated glass. Here's the tip. Pour a bottle of boiled water over the entire screen. The water will pronptly freeze, but it will freeze clear so you can now easily see through it. Keep some boiled water in your car. DO NOT USE HOT WATER only cold boiled water will do the trick. Try it!
Sport & Outdoor - Others Logo
My freezer keeps icing over into a solid block, and it stops working
possibly the drain is plugged or the drain line, which runs down from freezer on back of unit, to the drip pan underneath. U can blow it out with compressed air
May 29, 2012 | Maytag Refrigerators
excess frost and condensation
Could be that it is not getting a good seal when the door is shut. Check for obstructions causing that and check the door seal to see if it needs to be replaced.
Mar 13, 2017 | Sanyo SR-9510W Refrigerator
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
Aug 27, 2008 | Freezers
1,620 people viewed this tip
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
