Tip & How-To about Washing Machines
Hotpoint, Creda and Indesit error code definitions. Over 280 of them
For error code definitions on Hotpoint, Creda and Indesit Appliances use this link or if you need a workshop manual for Hotpoint WMA or WM washing machines use this link
Washing Machines Logo
display f-01 showing up
"Error F01" is indicating that the motor triac has short circuited on main PCB, this is part of the electronic speed control for the motor.You can do simple checks like motor connections/brushes etc.If the connections are seems to be perfect check the wiring whether it has continuity from motor to PCB. If there is no continuity then the PCB is faulty.
Hotpoint's advice is to call an engineer, it is not really a DIY repair, unless you have a good knowledge of electronics.
Thank you !!
May 25, 2010 | Hotpoint Aquarius WD640 Front Load...
my machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
Mar 11, 2010 | Hotpoint Aquarius WD640 Front Load...
my hotpoint if flashing f-03 and stopped working, what does this mean?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F03 means you have a faulty thermistor. Check; thermistor, connections or associated wiring. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Washing Machines
all lights on front flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If all the LED’s are flashing then you had better call out an engineer with the right test equipment because only a few LED’s should be flashing at any one time to indicate which area the fault is in. Click on the link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Aquarius WF000 Front Load Washer
F05 keeps coming up on my ultima 860 hotpoint 1600 spin w/m,we cant find manual,what is problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fo5 is a pressure switch fault; areas to check are pressure chamber for blockage, pressure pipe sump and pump. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
311 people viewed this tip
Top Washing Machines Experts
