Tip & How-To about Computers & Internet
How to convert Blu-ray movies to Apple ProRes 422 codec on Mac
Thanks to its outstanding technical characteristics, Apple ProRes 422 brings powerful new capabilities to Final Cut Pro editors. It will fit flawlessly into demanding editing and effects workflows. ProRes 422 is a better choice for ensuring all creative work to maintain its original, pristine color and detail, from capture to final viewing.
However, there are seldom Blu-ray applications developed for Mac users, not to mention a program that can rip Blu-ray to Apple ProRes 422 codec for editing in Final Cut Pro. In order to make some BD HD contents into my own film works in FCP, I would like to see a straight BD conversion to Apple's PrORes 422 codec, because this codec remains the stunning HD quality and has fast decoding speed and low compression rate. However, I have no luck, and I can not find a program to achieve this goal directly without the help of third party software. Right now, I have to use Pavtube Blu-Ray Ripper for Mac to convert Blu-ray to h.264 MP4 HD first, and then convert again to ProRes 422 using Compressor. This workaround seems a little troublesome and time consuming, because a straight conversion would save me 2 hours. Following is my workflow, and how about yours? Would you like to share?
Firstly, using Pavtube Blu-Ray Ripper for Mac to convert Blu-ray to h.264 MP4 HD:
1. Click "DVD Folder" or "IFO File" to load BD files
2. Click on the pull down menu after "Subtitle" and "Audio" respectively to select your needed subtitle and audio track to convert.
3. Click on the drop-down list of "Format" to select "HD Video" > "H.264 HD Video (*.mp4)" as output format
4. Click on "Settings" button to adjust audio and video parameters
Bit rate, aspect ratio, frame rate, sample rate, and channels are all changeable in the following interface, so you can adjust them according to your own requirements.
5. Click "Convert" button to start ripping BD to H.264 HD Video (*.mp4)
Once finished, click on "Open" button to get the output files for Compressor.
Afterwards, convert h.264 MP4 HD video to Apple's PrORes 422 codec with Compressor.
The detailed steps of this part are skipped, if any of you have figured out a straight way to convert Blu-ray to PrORes 422 codec, please let me know, and any suggestion is appreciated. Thanks in advance.
For more: http://www.pavtube.com/blu-ray-ripper-mac/
Computers & Internet Logo
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file. And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac. Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac. Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos. Step 2. Choose Apple ProRes codec for Final Cut Pro. Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.) Step 3. Merge Canon MXF files. (Optional) Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output. Step 4. Convert MXF to Apple ProRes MOV for Final Cut. Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio. After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Convert AVCHD Files to Apple ProRes 422 for FCP with Best Camcorder Software for Mac Do you have problems of importing AVCHD 1080/60p, 1080/50p, 1080/60i MTS or M2TS files to Final Cut Pro and want to find camcorder software on Mac OS X to Transcode AVCHD files to Apple ProRes Codec for editing in FCP without rendering? As the best camcorder software on Mac OS X for Sony, Panasonic, Canon, JVC camcorders, Aunsoft Final Mate for Mac is featured with one most important feature for Mac users-help Convert AVCHD video footage to Final Cut Pro ProRes formats including Apple ProRes 422 Codec, Apple ProRes 422 HQ Codec, Apple ProRes 422 LT, Apple ProRes 422 Proxy, Apple ProRes 4444 Codec. With Final Mate for Mac as the default camcorder software on Mac, you can choose preferable format for editing on Final Cut Pro without rendering. Final Mate for Mac also support converting AVCHD files to Apple Intermediate Codec(AIC)for editing in Final Cut Express or iMovie. The guide will share with you a easy and fast method of Converting AVCHD files to Apple ProRes 422 with featured software for camcorder on Mac. 1.Run AVCHD to Apple ProRes Converter for Mac and add AVCHD files. Launch Aunsoft Final Mate for Mac and add AVCHD files to the program by clicking on "Add" button to browser AVCHD file path on your local Mac computer. Then all AVCHD MTS/M2TS clips will show in Resource Tab of Final Mate for Mac. 2.Join AVCHD files and choose Apple ProRes 422 as output option. Directly drag and drop AVCHD files from Resource Tab to Movies Tab or Timeline to create a new movie and join AVCHD files into one for converting to Apple ProRes 422 Codec. There will be a pop-out window during the process shown as following: Please choose "Create A Single Movie" to merge all AVCHD video footage into one movie. 3. Start converting AVCHD to Apple ProRes 422 Click on Export button and follow Export into Editor > Final Cut Pro > Apple ProRes 422 HQ(*.mov) format to choose your output format for converting AVCHD to FCP supported format. Confirm your settings and click ok to starting conversion. Minutes later, you can access combined Apple ProRes 422 MOV movie by clicking on "Browse for Export Path". Now you are able to edit AVCHD files on FCP without rendering with the help of Final Mate for Mac as the best camcorder software on Mac OS X.. Tip: If you use iMovie or Final Cut Express for AVCHD editing, you may be interested to know how to Convert AVCHD files to Apple Intermediate Codec for iMovie/FCE.
Jun 28, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
183 people viewed this tip
David Payne
David Payne
