Tip & How-To about Computers & Internet
How to set Internet Explorer 8 to open in maximized window always?
I saw most of the people were asking for the option to maximize all Internet explorer windows size. There are some tricks which might work only for some windows but not for all the Internet Explorer windows. As I am working as a technical support, I found an option to set all Internet Explorer Windows maximized.
I will provide you the steps to set this potion, please try this and let me know if this worked for you.
1. Open Internet Explorer and press F12 to open Developers tools windows for Internet explorer.
2. Click on Tools and select Resize.
3. Select the maximum screen resolution size you have.
4. Close the Internet explorer and reopen it to get the maximized windows.
From now you will be able to open any Internet explorer windows in maximized size even though if you open a link right clicking on it and select "Open in a new window".
Ref: http://www.techiesspot.com/index.php/topic,312.0.html
Computers & Internet Logo
opening new window, window is reduced in size. Any tricks?
Generally, it opens up the same size it is closed. Try opening it up...either webpage or document...maximize it to fit the screen...go to file>exit or close....don't use the X at the top of the screen. The next time you open it, it should be maximized. Try it out! I know it works with webpages.
-rate if this post helps :)
-best of luck
Oct 20, 2010 | Acer Computers & Internet
Default maximize IE8
Open IE and Select Tools then click on Internet Options after that navigate to Programs tab and you will find first option for setting your default web browser select IE8.
Jul 13, 2010 | Microsoft Internet Explorer 8
When I open Internet explorer or any web sites on IE they appear
TIPS:
The default behavior for IE is to open at the same size it was at the last time it was closed.
While the default does apply in many cases it's not always consistent.
Try the following workaround.
Open a single IE window to the smaller size.
Drag the corners of the window until it completely fills the screen.
Do not use the maximize button to enlarge the window.
Hold down the Ctrl key, keep it depressed,
and using the mouse click File and then Exit on the menu bar.
Do not use the "X" in the upper right corner to close the window.
Internet Explorer should now open in a full window.
If it still opens to a smaller size repeat the above instructions, substituting the "Shift" key for the "Ctrl" key.
Jul 11, 2010 | Microsoft Internet Explorer 7
Acer Aspire One /Internet Explorer color appears in negative.
Try updating your DirectX files, can be done from here.
http://download.cnet.com/3001-20_4-10176490.html?spi=308dc021e8db6edb867480b0ab606bb6
Hope this does the trick
Please rate FixYa Experts assistance, whether your rating is good or bad helps The experts immensely.
Thank you for taking the time.
May 26, 2009 | Acer Aspire One PC Notebook
display on Internet expolrer 7
Use mozilla firefox.
Uninstall IE7, it sucks...
Feb 19, 2009 | Microsoft Internet Explorer 7
397 people viewed this tip
David Payne
David Payne
