Tip & How-To about Washing Machines
How to have a Clean Washer
If you are wondering how to clean the clothes washing machine then here is what you need to know.
Your washing machine works hard at cleaning your clothing, but once in a while you need to give it a good cleaning also. Whether you have a front loading washing machine or a top loading washing machine, you still should take the time to clean it once in awhile.
First take a good household cleaner and wipe down the outsides of your washer. Then wipe down the inside of the lid and on front load washing machine, the rubber just inside the door. To get the rubber clean you may need to move it around, pushing and pulling on the rubber to remove the wrinkles temporarily, to get into them and get the gunk out.
Then you are ready to clean the inside of your washing machine.
Some prefer lemon juice and others white vinegar. Either one is good, but the vinegar may be better at controlling odor in the washing machine. For either one turn the washing machine to the highest load or water setting and fill the machine. Add 2 cups of lemon juice or vinegar to the machine. Run it for a few minutes and then let it sit for at least an hour. Then let the machine finish the cycle. Run another cycle after with 2 cups of bleach. Also let the bleach sit in your washer for at least an hour. The run another complete cycle to rinse out your washing machine thoroughly.
This should give you a clean washer and hopefully you had fun washing the washer.
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
http://www.fixya.com/support/r3867591-washer_troubleshooting_water_not
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
http://www.fixya.com/support/r4312694-washing_machine_maintenance
Washing Machines Logo
What lime scale / detergent remover can be used for regular cleaning of my front loader.
Front-loading washing machines are energy efficient and use less detergent than top-loaders, but they sometimes have a tendency to harbor mold and unpleasant smells. By giving your washing machine a quick clean once a month, you'll keep your front-loader fresh, which means cleaner clothes, too. This eco-friendly method doesn't use bleach, costs only pennies to make, and comes together with ingredients you already have on hand.
What You'll Need:
  • 2 cups vinegar
  • 1/4 cup baking soda
  • 1/4 cup water
  • Scrub sponge
Directions:
  1. Start by mixing together the baking soda and water in a small bowl. This is going to be the "detergent" for cleaning the washing machine. Pour the vinegar into a measuring cup and head over to your washing machine.
  2. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. Set your washer to normal load at the hottest water setting. Close the door and start the machine, letting it do all the hard work for you. The baking soda and vinegar naturally break up mineral deposits and any mold growth while cleaning and refreshing your washing machine.
  3. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue. Wipe clean with fresh water.
  4. Your washing machine is sparkling clean and ready to do a load of laundry! Give your front-loader a cleaning once a month to keep your clothes smelling fresh and your machine working in tip-top condition.
Mar 20, 2015 | Washing Machines
Bravos 600 washing machine does not clean clothes
Do you have hard water? It is possible that if you have hard water that your screens are plugged by corrosion and need to be cleaned or changed.
Aug 27, 2014 | Washing Machines
Washing Machine
no you dont have to take the machine apart all the time usually the machine will flush itself but you need to run a empty load of HOT water and detergent and bleach in rinse to help clean the outter tub
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
wash cycle water level
the water needed needs to just come up right under the door this is how much water they use cause they use a tumble wash to clean the clothes
low water preasure is a problem but also make sure both water inlets are being used (hot and cold) even if you dont have hot attach a y hose the machine needs both inlets in use
these machines use very low water usage but they still need a fill up point
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaves a white film on dark cloths.
is she using powdered soap? if so shes been using too much. shell need to clean out the washer. a bottle of white vinager in a hot water wash with no clothes will clean it out. tell her to cut back on the soap. the box will say use a whole scoop. but thats just to get you to buy more soap. you only need half of that
Nov 28, 2007 | Washing Machines
6,506 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
