FixYa.com
Ink absorber full!
eagle338
By Wiz eagle338
Rank: Wiz
Rating: 80%, 860 votes
posted on Mar 10, 2008
Helpful (85)
This error is common in all the newer variants of canon printers.. Canon charges 50-80$ to fix it! But it can be fixed by following the steps below:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with o
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Did you find this Tip Helpful?
Comment #1
posted on May 01, 2008
ricouzuki
By Wiz ricouzuki
Rank: Wiz
Rating: 83%, 31 votes
The Ink absorber is for waste ink when the printer cleans the printheads. All printers have this pad. If you reset this ink counter without replacing the ink absorber pad the waste ink will eventually leak out of the printer!!!!
Comment #2
posted on Mar 20, 2008
pincer
By Wiz pincer
Rank: Wiz
Rating: 84%, 51 votes
Lexmark X1150 driver for that vista computer... posted by FuzzyT on Mar 19, 2008 Report abuse
I was on line with "Eagle" when I lost my connection about my Lexmark X1150 driver for that vista computer.
http://www.fixya.com/support/t454059-lexmark_x1150_driver_vista_computer
Can you Help with these Printers problems?
Canon PIXMA iP90 Mobile Printer
error says color ink not...
Printer won't print. Says color... Answer This...
Your solution of June 2 to...
I don't see any solution. What... Answer This...
dual sim not working
I put 2 sim,it was reading both... Answer This...
Cannon iP90
Urgetn help needed. New... Answer This...
black ink
when you print in black, each... Answer This...
Sponsored Links
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
