Tip & How-To about Computers & Internet
Hard Drive Basics and Beyond Part3
Have your Windows CD handy as it will ask you to place it in the tray.
And Finally
Use a driver saver tool to avoid all that cruising the internet for the motherboard drivers your computer came with. This will save you from hours of frustration and fix any lost drivers that windows or malware have destroyed or corrupted. I use (Driver Backup 1.0.0.1) Which is
available at Cnet's download.com. Copy the files you save to a flash drive or CD and you will never regret it!
The DEAD Hard Drive! Or is it?
If all else has failed and Windows no longer starts up as it should, you will have ended up here in the Uh Oh area!
By now your local PC shop has told you that you have a virus and you need to format your hard drive because they are too incompetent and lack the skill and education to remove the virus with a standard Antivirus that any moron can buy at the local Costco, Walmart Target store or mall.
You didn't think they actually used anything you can't buy yourself did you?
The sad fact here is, that most people can do everything most every PC repair shop does on a daily basis in their own home with very little effort. Most PC shops simply Start your PC and if it won't start Windows properly, they will tell you that a hard drive wipe or (Format) is the only
way to save your computer.
Nothing could be further from the truth!
Using the basic methods I have described above you can solve most of these problems yourself.
If you have a virus, just refer to my Article titled (Virus Facts and FYI).
Remember that almost no PC shop will care one iota about your personal data, or how long it took you to scan those family photos you use as a screensaver, or the Long reports you wrote for the Boss, or that novel you have been working on for the past 3 years.
There are some exceptions of course, and there are some genuine Computer Techs who will go that extra mile just to see you smile. But most of these guys have messy hair, work at home or smell like last nights Pizza. These guys are the ones you want. Not all of them are as wise as they should be, and some have Ego's the size of Dallas, while others will unscrupulously swap parts with your PC to upgrade their own PC hoping you will never find out. I know of a large computer firm near me that does this routinely and they have the whole town fooled.
But they DO exist, and have a head full of knowledge that will benefit you tremendously should you find the right one. So if you feel inadequate to use the steps provided so far, find a guy that has no shop, but everybody knows and trusts with their PC,
Back to the dead drive, (sorry I wandered)
So here you are with a hard drive that no longer boots or runs windows.
What about your data? You can save that with a USB to IDE/SATA connector.
This little device usually sells for under $20 and can be attached to any hard drive you care to place on it except for the SCSI variety.
To use this device, you will need to:
1. Remove your hard drive from your PC
2. Find a PC with enough free hard drive space to store your data on.
3. Scan the drive for viruses and malware with this other PC.
4. Scandisk and Defrag it to speed up data transfer and eliminate errors.
How do I know where to find the files I want to save?
Here is what you need to do first:
1, In XP go to (Tools), then (Folder Options) then (View) and uncheck anything that says hide.
2. Then go to (My Computer) and open your main drive, Usually C:
3. Open a folder called (Documents and Settings)
4. Look for a folder with your Login name and open it.
5. Do not drag these folders to your computer (Application Data, Cookies, My Recent Documents, NetHood, PrintHood, SendTo, Start Menu,
Templates, or Windows) as these will be useless on your newly formatted drive. If you have to format! and we really DON'T want to do that!
6. Create a new folder on the desktop of this other PC and call it anything you want and drag the rest of the folders there.
Take care to not delete or move any of these folders since we will be trying to restore your computer to as close to the pre-crash state as we can without losing data. If all goes well, your desktop will look the same, your (My Documents) folder will be intact, and most, if not all of your original programs will run as they did before your PC crashed.
Now you have a backup copy of your crucial files and can safely try to revover your hard drive and windows installation.
What if I use Outlook or Outlook Express!
(This will only work if you can still access windows)
This is usually only a problem on PC's where the email client is based on the ISP's settings and local mail delivery system. Saving your Emails is as easy as clicking one email item, going to the Edit tab and selecting all, then copy and past the selected Emails to the folder of your Choice, Obviously you should name it My Email or some such thing. Do the same for any Folders you created with your email client by opening them, select all, then copy and paste. When your new windows installation finishes (if you end up reinstalling) Simply drag and drop them right into the email clients inbox window and you'll be good as new.
Now you can reinstall your hard drive to your original computer and begin the data recovery, or reinstallation process. This will require you to use your original Windows CD and Product key.
On To The Real Fun Now !!
# Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
Computers & Internet Logo
i can not open my cd it will not ejet
This is happening when it is jammed with some wrong inserted disk ..or it does not make contact with the main board so it has no power to react ..or ..if it was disabled..(in the last case it may open when you manually press the button ..)I suggest to take a look on the tray of the drive ..and see there is a hole on it ..If you insert a paper clip in there and press it will manually open..try to remove whatever is inside and place another disk to verify its functionality ..if it works ..fine ..if not ..try to see if it has the icon in my computer ..and if not try to reinstall its driver , by going to device manager ..and select in the list ...right click and update driver..windows should have its driver built in ..
In case it does not react ..go on the back of the laptop and see that it has a screw (or 3) that holds it in place ..remove them and slide the drive ou t..Place it back and restart ..and make sure it is plugged well ..If it still not working you will have to change it cause it may be damaged..
Another thing you may try after removing the disk or manually open i t..is to insert a windows disk and try to boot from the disk ..(go to bios by pressing F10 on start ..and in there select the cd to be the first boot device ..save the settings with F10 and exit ..). when you boot again it will ask to press any key to boot from cd ..if you have a windows cd inside..and you may reinstall the OS and eliminate any errors..this also mean the drive is functional and probably has a damage on the exit mechanism if t still makes the same after reinstalling windows.
Jan 13, 2012 | HP Compaq nx9030 Notebook
My dell insprion 1520 wont go past boot screen it stars then goes to a black screen that says start up repair or start windows normally but when i click star up repair nothing happens then i pick start windows normally it starts a loading screen that says windows and it will keep loading forever and nothing happen can someone help me with this problem
Place your windows cd/dvd in the tray and boot to the cd. When asked if you want to install windows, there will be a repair option further down towards teh bottom, or you will be asked to click R like before. The repair only works if the cd is in the tray.
Aug 26, 2010 | Gateway 7325GZ Notebook
All In One Centre
- i like your problem can u give me more variables for this case?
-OS used
-type of connection(wifi light if applicable)
-workaround try to scan via MSPAINT on file their is scanner and cameras- to scan from the PC->printer
Sep 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
hHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
190 people viewed this tip
David Payne
David Payne
