Tip & How-To about Computers & Internet
MAKING AN INVISIBLE FOLDER
Invisible folder....... Create a new folder, and when u are about to rename it press and hold ALT key and when type 767, and then leave the ALT key, and the folder will be created without the name, and then customize it , change the icon by using a blank icon, there will be an empty space choose that one and click ok so there will be your invisible folder..... try it but your imagination is required to access the folder
Computers & Internet Logo
profile service service will not allow me to logon
First of all start your computer in safe mode. This can be achieved by pressing F8 during the start-up of your computer. If this is done correctly you'll get a menu where you can choose to start your computer in safe mode.
After it is booted in safe mode follow these steps:
  1. Click Start, type regedit in the Search box, and then press ENTER.
  2. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
  3. In the navigation pane, locate the folder that begins with S-1-5 (SID key) followed by a long number.
  4. Click each S-1-5 folder, locate the ProfileImagePath entry in the details pane, and then double-click to make sure that this is the user account profile that has the error.
    • If you have two folders starting with S-1-5 followed by some long numbers and one of them ended with .bak, you have to rename the .bak folder. To do this, follow these steps:
      1. Right-click the folder without .bak, and then click Rename. Type .ba, and then press ENTER.
      2. .bak, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493039.png" alt="2493039" title="2493039">
      3. .ba, and then click Rename. Change the .ba to .bak at the end of the folder name, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493040.png" alt="2493040" title="2493040">
    • If you have only one folder starting with S-1-5 that is followed by long numbers and ends with .bak. Right-click the folder, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
      1. .bak, and then click Rename. Type .ba, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493038.png" alt="2493038" title="2493038">
  5. Double-click the folder without .bak in the details pane, double-click RefCount, type 0, and then click OK.
  6. Click the folder without .bak, in the details pane, double-click State, type 0, and then click OK.
  7. Close Registry Editor.
  8. Restart the computer.
  9. Log on again with your account.
Dec 24, 2013 | Computers & Internet
How to create a really invisible folder
ok seemingly silly question, but how do i delete this folder now??
Mar 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
116 people viewed this tip
David Payne
David Payne
