Tip & How-To about Computers & Internet
How to bypass Windows XP password? We often meet the headache stuff that don't know the Windows system password at the critical comment. How to do if you made a Windows XP password that you never be care of it? How should you do when your computer has parents controlled by the XP Administrator password? Or you need to borrow a friend's computer to carry out emergency work, but you don't know the admin password...Let's share some tips about how to bypass windows XP password. First things first, try the guest account. Simply enter 'Guest' in the user name box, or click on the account labeled Guest. Sometimes people will have these account enabled without even realizing it, and many times they are left without a password. If this doesn't work for you, or you require a little bit more access than the Guest account provides, read on. Next up is Windows XP's built in 'Administrator' account. This account is created during Windows installation, and is not accessible under normal circumstances. Many computers, especially those that come from Dell or similar companies, leave the Administrator account without password protection. To get to this account, boot the computer into safe mode. You can do this by holding down the F8 key during startup, and selecting Safe Mode from the Windows boot menu. Once the computer boots into Safe Mode, you'll have access to the Administrator account. Things will look a little weird in Safe Mode, but don't worry, things will be fine when you boot normally again. Once Windows finishes booting, try getting into the Administrator account, leaving the password field blank. If you're unable to get in this way, then there is a password on the account, and unless you can guess it, you're going to have to try something else, and you can skip the next paragraph. If you're in, then there's no limit to what you can do. Besides, you can also take use of Windows password reset CD to remove Windows XP password if you forgot Windows XP password. Well, how can you get Windows password reset CD? Just download Windows Password Unlocker and a blank CD, you can DIY a Windows password reset CD in 4 steps. In fact, Windows Password Unlocker can be used to bypass windows 7 password, bypass windows vista password , bypass windows NT password and so on.
Computers & Internet Logo
password recovery
Forgot windows password ?
Don't worry - it happens to a lot of people.
Vista and Windows 7 allow you to create a password reset disk.If you installed Windows XP, boot up Windows XP in Safe Mode and log on with the built-in administrator account.
If you feel the methods above complicated, you can use Windows Password Reset ,it is easy and safe.And a systems support.
Jun 12, 2012 | IBM ThinkPad A21m 2628 Notebook
How to bypass a dell dimension b110 password
It's not so clear since you haven't mention which password, whether Bios password or system password. If it's Bios password, remove the Bios battery and leave it outside for few mins and reinsert it. That will solve the problem. But if it's system password (password to be typed in when you are logging on to your system), it depends on the operating system on how to bypass it. For windows XP it's easy with some key strokes but for win vista and win 7 it would be much tougher since higher security feature is implemented with these operating system. Let me know if your problem is the system password with the operating system mention in your comment. Good luck.
May 14, 2010 | Dell Dimension™ B110 PC Desktop
forgot password, window xp home edition, how to by pass
Here is a little trick to use that may or may not work:
Start the computer in safe mode and log on as administrator. It's surprising how many people set up their XP computers and password protect their profile, but forget to password protect the administrator account. Once in, you can change your password in your own account.
Feb 01, 2010 | Microsoft Windows XP Home Edition
password
the link and the video below will show you how to bypass an XP admin password.
Bypassing XP password
Bypassing XP password the video
hope this helps, but if you have other question please lemme know.
Nov 04, 2008 | Microsoft Windows XP Professional With...
192 people viewed this tip
David Payne
David Payne
