Tip & How-To about Washing Machines
Hotpoint Washing Machine Error Codes or Fault Codes
If you are having a problem with your Hotpoint washing machine it is helpful to know what the error code means. Some of the problem are very simple to fix and do not require a service call to remedy the problem. Here is a list of error codes and the meanings for Hotpoint washing machines
If your error code has an E in front of the number and not an F as shown here, the meaning of the code is still the same
# F10 - This means there is no cold water coming into your washing machine You should check and make sure that the valves are on and that the hoses are not kinked.
# F11 - This means there is no hot water coming into the washer. Again make sure that the valves are on and that the hoses are not kinked anywhere. Also hot water will freeze before the cold water does, if it is very cold where you washer is, check for frozen pipes.
# F12 – This code means that the water is not filling when calling for mixed temperature water. Again, check the hoses and valves.
# F13 – If you have water supply problems this code could also display. Check all hoses and valves.
# F14 - A If this code comes up you have a problem with the washer water heating system. It is usually best to get a professional to repair this problem.
# F15 – The water is not being drained from the washing machine properly. Check the discharge hose to make sure that it is not blocked and that it rises to the minimum height requirement for your washer.
# F16 – The water level is or has been too high in the washing machine. The water inlet valve is probably not closing properly. Turn off the water at the hot and cold water valves and replace the water inlet valve.
# F17 - Door is not closing properly. Firmly push the door closed, and the washing machine should work. If you cannot get the machine to run by slamming the door, then you will need to have the door switch repaired or replace it your self.
# F20/1 – This means that you have a problem with the thermistor that senses the water temperature in your washing machine. It will need to be replaced. This error also could occur if the temperature where the washing machine is, is below freezing.
# F30/31 – This means that there is a problem with the washing machine motor. Check that you do not have too much in the washing machine. There also could be a communication problem to the motor. Unplug the washing machine to reset it and then try to run a cycle again.
# F40 - Water is below the minimum level for the heater to be working. You need to find out why there is not enough water entering the washing machine.
# F41 – There is a problem with the water level detection system.
# F50/51 – This means that the washing machine has lost its programming. The washer will run in a default mode till you can get it reprogrammed.
Washing Machines Logo
Error code ''test'' hotpoint washer mod 860
iv just had to do it lol, hold down the on off + start button together for the cycle aprox 3 mins then it will say done, then u can go nuts and wash untill ur hearts content.
Aug 17, 2009 | Washing Machines
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
hotpoint wt741 f11 what does this mean
Hotpoint Error Codes.
Hotpoint washing machines are among the most common found in the Uk and like any mechanical device they will occasionally breakdown or develop a fault and need repairs.
Being a very popular make means that most parts supplier will keep there parts in stock and because so many suppliers keep Hotpoint parts stock this also drives competition hence driving down the price of parts if you should ever need them
One problem many people including some engineers face when faced with a faulty Hotpoint washer is knowing what the error code mean, so here are a list of error codes and there meanings for Hotpoint washing machines
These error codes can some times have a E in front of the number and not a F as shown here, but the meaning of the code is still the same
# F11 - This means there is No hot fill.The ambient temperature is probably below freezing perhaps due to the plumbing becoming frozen. Also verify that the taps are on or if the drain hoses are kinked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 26, 2008 | Washing Machines
error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
512 people viewed this tip
Top Washing Machines Experts
Marvin
Marvin
paul
paul
