Tip & How-To about Washing Machines
How to Install Washing Machine Belts?
The procedure is as follows:--
1) First of all unplug the washing machine from main power outlet.
2) Take it out away from wall.
3) Remove the screws from its back to remove the back panel.
4) You will see the belt once the back panel is removed.
5) Now push the belt adjustment lever towards the down side. so the belt will get loose.
6) Carefully remove the old belt.
7) Place the new belt in the same position as old belt was placed.
8) Refit all the parts in the same place and same order in what they were removed.
This will help. Thanks.
Washing Machines Logo
My washer stops several times at the beginning of wash flashing F1 I have followed the instruction from the referrence booklet to pause and start again but flashes the same, eventually after 2-3 attempts it proceeds. Towards the end however it stops with 14 min. left in the cycle. Is this something serious?
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
States F1 everytime going to wash
#1
#2
#3
#4
#5
#6
May 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 problem
#1
#2
#3
#4
#5
#6
Jul 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
help me immediately, please
Actually, the "kit" is a DIMM that plugs into the controller on the right side of the copier (when looking at it from the back of copier) On this model, you need to add 64mb of RAM if you want to add functionality to print and scan, along with the DIMM. Yes, there are 2 different DIMM's for this,....one is Print and one is Print/Scan.
PS: there is a kit to install said items that includes buttons for the controll panel and DIMM, however, the memory is separate (laptop memory or SO DIMM)
Jun 29, 2009 | Ricoh Aficio 1035 Copier
F1 beeping pauses the washing cycle.
#1
#2
#3
#4
#5
#6
Apr 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
254 people viewed this tip
Top Washing Machines Experts
