Tip & How-To about Refrigerators
How to Change the Filter on an LG Refrigerator
The procedure is as follows:--
1) The water filter located in the top left corner of the refrigerator in the small tube with a bottom hole.
2) Before removing the water, drain the water in the chamber by turning the filter handle counterclockwise.
3) Then carefully slide the cartridge out of the tubing.
4) Take the new filter and push the replacement filter into the filter holder.
5) While placing the new filter the filter handle should be positioned vertically.
6) After placing the filter turn it clockwise to make the new filter fit properly.
7)Test by running water in to the tubing and check if its going freely or getting blocked.
This will help.good luck.
Refrigerators Logo
HOW TO CHANGE refrigerator GE ARCTIC PS123SGNA water filter
Filter should be in the fresh food section top right back corner. It unscrews to the left about a 1/4 to 1/2 turn and pulls down. Reverse procedure to install. Not hard at all.
Apr 06, 2015 | GE Refrigerators
How do I change water filter
Hello Anita;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, so I am going to have to tell you where the water filter might be.
1.) On the lower, front bottom grill or toe plate, in the center there is a round hole. In this hole is your water filter. Grab the end of the cylinder and turn 1/4 turn counter clock wise and pull out. There will be some water in the filter. Slide the end cap off the old filter and slide it back on the new filter. Insert the new filter, push in and turn 1/4 turn clockwise.
2.) In the upper back right hand corner of your refrigerator section is where your water filter is located. There is a plastic cover plate around it, but you can still see the bottom of the filter canister. Reach in and turn the bottom of the filter 1/4 turn counter clockwise and remove. Insert the new water filter and turn 1/4 turn clockwise.
After installing a new filter, there is air in the filter. Run your water dispenser until a steady flow of water come out. You will get air & water spurting out.
If you only have a ice maker, you will have to manually cycle your ice maker until it fills.
The water filter change light is not tied into anything in your unit. It is like a egg timer. Even when the indicator light indicates to change you water filter, you only change your water filter when either the water coming out of the water dispenser is slow or you are getting small ice cubes.
Nov 23, 2014 | Kenmore Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I remove the water purification filter. I bought a new filter to replace the old filter, but as soon as I pop the filter into place the leaking starts. I don't see water inside the fridge or freezer, but when the filter is in place I can see water dripping at the back corner (outside the fridge) where the clear plastic tubes go into the back of the fridge. THe water seems to be dripping on to the tubes from above, and the water ends up in the metal plate at the bottom of the fridge. When this plate overflows, the water spreads onto the floor. The flow is pretty steady when the filter is in place, so I've taken the filter out while I resolve the issue. The water dispenser doesn't work with the filter out, though the manual seems to indicate that it should. Can you help me solve this problem?
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
252 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
