Tip & How-To about Refrigerators
How to Change the Water Filter on a Refrigerator?
The procedure is as follows:--.
1) Locate the water/ice filter in the back of the refrigerator. Its located at the far back of the top shelf.
2) Carefully remove anything on the top shelf of the refrigerator that is in the way of the filter
3) Then remove the housing of the filter You will have to twist it and remove the housing.
4) The housing will have small arrows showing which way to turn.
5) Now remove the existing filter from the housing and throw the old filter.
6) Insert the new filter in the housing.
7) The fit all the parts you removed in reverse procedure.
This will help.good luck.
Refrigerators Logo
GE 18.0 Cu. Ft. CleanSteel Top-Freezer Refrigerator - GTL18JCPWRBS Water isn't going to the ice maker even though the water supply is on
Locate and replace the water filter. It should be covered in the owners manual. If that is not the problem, then the solenoid that turns on the water supply is shot, at which point you are probably better off just buying a replacement ice maker.
Oct 02, 2013 | GE GTL17JBSBS 28" 16.6 Cu. Ft. Top-Freezer...
Model MF12266AES French door fridge seems to be stuck in defrost mode. We were told there is a way to 'reboot' the system on the fridge (maybe by pressing the light button inside a number of times). Does anyone know how to 'reboot' the fridge?
Hello Jennifer
Here is my step by step instructions to follow.
1. Look inside your refrigerator and locate the temperature control switch. This is usually situated around the middle of the refrigerator's back panel. Some switches have a wheel mechanism, whereas others use digital displays.
2. Turn the temperature control wheel down to zero or switch to "Off" if you have a digital display.
3. Move your refrigerator away from the wall. Refrigerators are extremely heavy, so enlist the help of another person, if possible.
4. Unplug the refrigerator cord from the wall outlet. Leave unplugged for around two or three minutes.
5. Attach the power supply back to the wall outlet and position the refrigerator back against the wall. Your refrigerator temperature is now reset. Switch the temperature control back to "On" and adjust the temperature to the level required.
6. Open the ice making area of your refrigerator if it is producing watery ice cubes or an inconsistent water supply.
7. Locate the water filter status light inside the ice maker. This is usually a small rectangular light situated at the side of the ice maker.
8. Push the switch next to the status light seven or eight times in quick succession. This will reset your ice maker.
9. Check the status light. This should turn from red to green once the switch has been pressed several times. The green color indicates the ice maker has been reset.
Remember if you FRIDGE is on warranty you just send it first to the manufacturer.
Best Regards
Neciforo Llanto
Sep 21, 2013 | Refrigerators
Whirlpool ES5FHA refrigerator water dispenser is not working properly
Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in. Check at the bottom front grill for the filter.
May 29, 2012 | Whirlpool Refrigerators
water not coming out of the dispenser. Ice maker
Check the unit for an in-line water filter that may be plugged. Check your manual for the location and procedure to change the filter cartridge.
Aug 23, 2009 | Refrigerators
cannot locate water filter
From my experience the water filters for most refrigerator are near in the area of the Ice maker cubical.
Jul 16, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
186 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
