Tip & How-To about Computers & Internet
How to install fonts in windows 7
1. You can download the fonts for Windows from anywhere you like. If its in zip format then unzip it.
2. Right Click on it and then Click on Properties.
3. Under General tab you`ll see a Unblock Button, Click on it (Ignore this step if there is no Unblock button.
4. Now for installing you can either Double Click on the Font and Install it or you can drag and drop the font here "C:\Windows\Fonts"
Computers & Internet Logo
install myanmar font
How to install and use Zawgyi Myanmar Font
  1. Download Zawgyi Myanmar font and keyboard driver here.
  2. Find and Unzip the downloaded file
  3. If you know how to unzip the zipped file, skipped to Step 4.. Otherwise read on.
    1. How to unzip downloaded file
i.You need to have file compression software to zip or unzip the file.
ii.If you have winzip or similar software, you can use it to unzip
iii.Otherwise download z-zip application here
iv.Double click on 7z444.exe
v.Click Install
vi.Click Finish
vii.Right click on the downloaded file
viii.Select 7-Zip, then select "Extrace to"ZawGyiFont\" and it will create a "ZawGyiFont" folder.
  1. Installing ZawGyi Myanmar Font
i.Inside the folder, you will see the following.
ii.Click "Start" then "Setting" and select "Control Panel"
iii.Double click on "Font" folder.
iv.Copy the "Zawgyi-One-20051130.ttf" file and paste it to the "Font" folder above and finish the font installation.
  1. Keyboard Driver Installation
    1. Open the "ZawgyiKb_installer_I" folder under "ZawGyiFont"Folder
  1. Double Click "ZawgyiKb.msi" file and installation is completed.
  1. You sill need to set up Zawgyi Myanmar Keyboard driver to type using Zawgyi Myanmar font.
  1. ZawGyi Myanmar keyboard setup
    1. For Windows 2000
i.In Control Panel, double click on "Regional Options"
ii.Click on "Input Locales" tab and click "Add"
iii.In the Keyboard Layout/IME: drop down menu, select "Zawgyi Myanmar Unicode Keyboard" and Click "Ok" then Click "OK" on "Regional Options" window
iv.Keyboard installation completed.
  1. Windows XP
i.Open "Regional and Language Options" in the Control Panel
ii.Click on "languages" Tab and click "Details"
iii.Click "Add"
iv.Check "Keyboard layout/IME: check mark and select "Zawgyi Myanmar Unicode Keyboard" from the drop down list and press "Ok"
v.Press "Ok" on "Text Services and Input Languages" window and press "Ok" on Regional and language Options" window
  1. Testing Zawgyi Myanmar Font
    1. Open a blank word document.
    2. Select Zawgyi-One in "Font" drop down list.
    3. Type some words, and try Ctrl+Shift OR Alt+Shift to toggle between Burmese and English. (NOTE: Either Ctrl+Shift OR Alt+Shift will work as toggle mode. You can set up this key combo as the way you want by pressing "Change Key Sequence" button in Input Locales
Apr 15, 2014 | Lenovo Computers & Internet
manual formsi-7104ver:1.0 motherboard
The MSI MS-7104 version 1.0, motherboard, is also known as the MSI PM8M-V motherboard,
http://www.msi.com/product/mb/PM8M-V.html
Scroll down the page, and hover your mouse cursor on the heading - Download.
(Overview, Specification, Download, Support, Where to Buy)
In the drop down list left-click on - Manual
Under the heading Download to the right, left-click on the blue -
M7104v1.0.zip
Now left-click on the country nearest yours.
A small window will come up on the right,
Opening M7104v1.0.zip
If the circle to the left of Save File has a green dot in it, leave it.
If not left-click in the circle to the left of Save File. (Puts a green dot in the circle)
Go to the bottom right of the window, and left-click on OK.
A small window will come up on the left.
IN the wording at the top of this window tells you where the file will download to.
It may have Desktop, or My Documents, or Downloads in it. (Based on WinXP. Vista and Win7 is different) You may wish to write it down.
1) Desktop:
The file will be on your desktop screen.
2) My Documents:
Left-click on Start, then on My Documents.
3) Downloads:
Left-click on Start, then on My Documents. DOUBLE-click on Downloads.
Primer:
A ZIP file is used to send large amounts of information more easily.
A ZIP is 'unzipped' using an unzip program.
You should have WinZip on your computer. An unzip program. If not I suggest using a free alternative. One such alternative is 7-Zip,
http://7-zip.org/
{ 32-bit x86 is for the regular version of Windows XP Home Edition, or Windows XP Pro Edition.
The 32-bit versions }
When you see the zip file, DOUBLE-click right on it.
The Unzip Wizard should come up. Left-click on unzip in the right column.
Now go to the far Left side, and left-click on Extract All Files.
Left-click on Next, Next, and Finish, at the bottom of the three windows.
You will be looking at a window that has the file name next to a red PDF icon.
Double-click on it.
You are now looking at a PDF file form of the motherboard manual.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 16, 2011 | MSI PM8M-V Motherboard
how to install a downloaded font in a pc
First, the font file you downloaded may have been compressed to save space. If the extension is "zip" or "rar" then you'll need to uncompress it. Windows has support for the zip format, and all you need to do is double-click the file icon to start the process. If you aren't familiar with how to unzip files, this page can help.
Windows doesn't support rar format compression, so you'll need another program. WinRAR is one. It's free to download and try for 30 days, but you need to purchase it if you want to keep it. 7-Zip is a free program that unzips rar and zip files as well as many other formats.
Once you have extracted the font files (which usually have a ttf extension), you can just copy them into the Windows fonts folder at C:\WINDOWS\FONTS. Once in that folder the fonts are installed.
Jan 15, 2011 | Audio Players & Recorders
how do I unzip downloaded file on Vista and copy it to floppy disk,via usb to floppy converter? Thank you. Cathy.
Windows Vista has a built-in function for unzipping files in Explorer. Just right-click the filename and select Unzip from the menu. But I never use the built-in Windows function, because it's incredibly slow and has limited functionality.
My favorite is 7-Zip, which you can download from http://www.7-zip.org/. It will extract files of .zip, .rar, and many other archival formats, and it can split large files into small sections to be stored on several floppies.
7-zip adds a line in the context (right-click) menu of Explorer for 7-zip>, so you can unzip files right from Explorer. Splitting files requires starting 7-zip and finding the file in it's own explorer-like interface. Right-click the filename, and select Split... A little dialog box appears asking what size chunks you want to split the file into. In my test just now it defaulted to 1.44M floppy disk-sized sections. You also choose the folder you want the new files to go to. The actual splitting operation, even on this old Win 2000 computer splitting a 3.6M file, was virtually instantaneous.
The program is free for personal or business use.
Sep 21, 2010 | Toshiba Satellite Terca Portege USB...
How to install Fonts in windows 7
hello nirav702,
To install Fonts in Windows 7, simply follow this step:
1. Download Your fonts and then unzip
2. Right clik on it and then click on properties
3. Under the General tab You will see an Unblock Button (click on it only if u see the Unblock Button, if it's not then ignore this step)
4. You can either drag and drop the font to directory: "C:\Windows\Fonts" or u can just double click on the font and install it
hope this help
Apr 14, 2010 | Broderbund ClickArt 19,000 Fonts Full...
1,098 people viewed this tip
David Payne
David Payne
