Tip & How-To about Microsoft Windows XP Professional
How to make windows installer work in safe mode
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
To make Windows Installer work under safe mode, you need to create a registry entry for every type of safe mode you are logged in to.
  1. Safe Mode.
    Type this in a command prompt:
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control
\SafeBoot\Minimal\MSIServer" /VE /T REG_SZ /F /D "Service"
and then net start msiserver This will start the Windows Installer Service.
  1. Safe Mode with Network
\SafeBoot\Network\MSIServer" /VE /T REG_SZ /F /D "Service"
and followed by net start msiserver This will start the Windows Installer Service.
Microsoft Windows XP Professional Logo
Dimension 5100 and windows xp pro SP3 clean install
I was able to dig this up.
Reference: http://4sysops.com/archives/tip-how-to-install-and-uninstall-a-program-in-safe-mode/
Run Windows in safe mode.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\
Create a registry key REG_SZ key and call it MSIService and value data and call it Service, which is the windows installer. This will give you permission to uninstall windows service Pack 3 from add/remove programs while in safe mode.
May 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Can't install jave update
Try uninstall or reinstall again
You can't install things in safe mode.
Jan 08, 2010 | Computers & Internet
Windows Vista Installer corrupted/freezing
if you are sure that there is some problem in windows installer then you can download the windows installer from the following site and try installing it ....
http://www.microsoft.com/downloads/details.aspx?familyid=5A58B56F-60B6-4412-95B9-54D056D6F9F4&displaylang=en
and if you couldnt able to install in the normal mode then just go safe mode and try installing the windows installer ....
then the problem will surely be solved
you can go to the safe mode by pressing F8 at the time of the system boot ....
after pressing F8 you must choose the safe mode ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 09, 2008 | Microsoft Windows Vista Ultimate Edition
575 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
