Tip & How-To about Rock & Ice Climbing
Nokia Default Codes Most Nokia phones have the same default codes.The default code is entered for the first time on a new Nokia phone and it won't be accepted if the default code has been changed by its owner. Here are some default codes; Security Code: 12345 Phone Lock Code: 12345 Standard Bluetooth Pairing Codes: 0000 Nokia Secret Codes There are a lot of secret codes on the Nokia phone and I'm sure you are aware of it or even know some of it. The listed codes below may NOT work for all the Nokia phones or it is restricted to some Nokia phones but you can try it on your phone to find out. Here are some of the useful codes: #pw+1234567890+1# : Information about Provider Lock Status/Sim Restrictions. #pw+1234567890+2# : Information about Network Lock Status. #pw+1234567890+3# : Information about Country Lock Status. #pw+1234567890+4# : Information about Sim Card Lock Status. *#06# : Imei number (International Mobile Equipment Identity) or serial no. *#7780# : To reset the phone to factory settings. *#7328748263373738# : To reset the phone's security code. *#92702689# : Details about the phone: Serial no, month and date produced, the date the phone was purchased, date of last repair (0000 if not repaired at all). *#0000# : software version. *2820# : To add Bluetooth Device. *#7370# : To reformat the phone or Hard Reset (usually for Symbian phones). *#99# : GPRS Speed dial Code. *#746025625# : Details about the Sim Clock Allowed Status. *#7370925538# : To Reset Wallet Code (usually for S60 phones) *#3925538# : To Delete All Content in Wallet (if it ask for the phone lock code enter your phone lock or the default phone lock code). *#9999# : Details about the software version if *#0000# doesn't work. *#2640# : To display the Security Code in use. *#73# : To Reset the phone's time and also the game scores. *#7760# : To display the Manufacturer code. *#8110# : Details about the Software Version for Nokia 8110. *3370# : To activate Enhanced Full Rate codec (EFR) (which means your phone will use the best soud quality but the talk time is reduced to 5%). #3370# : To deactivate the EFR. *#4720# : To activate Half Rate codec (which means your phone will use the lowest quality sound but you would get 30% more of talk time). *#67705646# : To remove Operator Logo for Nokia 3110 and Nokia 3330. *#43#: To view the Call Waiting Status on the phone. *#30# : Enable to view the private number. *#21# : To check numbers that All Calls are diverted to on the phone. *#61# : To check the numbers that On No Reply calls are diverted to. *#62# : To check Divert If Unreachable/No Service calls are diverted to on the phone. *#67# : To check that On Busy Class are diverted to.
Rock & Ice Climbing Logo
security code
Have your forgot your security code of your Mobile Phone?What is Mobile phone brand and model?
you can use default code to reset it...Try 1234 or 0000 or 12345 these are default codes for NOKIA phones...If these codes not works get free master reset code from Unlocking4free.com for Nokia DCT Phones and Alcatel Old phones and reset it easily..
Oct 29, 2012 | Cell Phones
phone restricted,
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 12, 2012 | Nokia 6030 Cellular Phone
My nokia e72 is demanding a PUK code. please help
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Jul 19, 2011 | Nokia E72 Smartphone
I want to change Nokia 3110c security code from default 12345 to any other number
From your phone
menu>settings>security settings>change access codes>security code change>
then you enter the default of 12345, after that, you would be prompted to enter the new code of 5 digits. You would be asked to re - enter the new code. Then your code would be changed.
Hope that was helpful?
Please do indicate.
Mar 25, 2011 | Nokia 3110 Cellular Phone
914 people viewed this tip
Top Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you a Rock and Ice Climbing Expert? Answer questions, earn points and help others
