Tip & How-To about Washing Machines
LG Washing Machine IE Error Code
If you are getting the IE fault code or error code from your LG washing machine then you need to know why you are getting that code and what do you need to do to fix the problem.
This error code is caused when the washing machine does not fill up with water in about eight minutes. The washing machine gives its self eight minutes to reach the right water level. If there is a problem that keeps the water from entering fast enough the machine will shut down and give the IE error or fault code.
The most likely problem that will cause this fault or error code is that the water hose screens are plugged with dirt and debris. Most all washing machines have some type of water filter in the hoses or in the machine at the entering point for the water. Dirt and debris will build up in these filters till in restricts the water flow enough to cause this problem.
The other cause for this error is if you happen to reverse the hoses. If the cold water hose is on the hot side and the hot is on the cold side it can also cause to alarm. If the filters look clean then check the location of the hoses and make sure that they are properly connected.
Check that the water valves where the hoses connect to the domestic water supply are on completely. Some valves are difficult to tell if they are completely on or not.
If you need to reset your washing machine fault or error codes you can do this by unplugging the machine and then holding the start/pause button for five seconds. Then plug the machine back in and the code should be removed.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
Washing Machines Logo
Lg washing machine ie fault
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters
Dec 03, 2016 | LG Washing Machines
If you are getting the IE fault code or error code from your LG washing machine then you need to know why you are getting that code and what do you need to do to fix the problem. You get this code if you have a LED model You get this code if you have and LCD model This error code is caused when the washing machine does not fill up with water in about eight minutes. The washing machine gives its self eight minutes to reach the right water level. If there is a problem that keeps the water from entering fast enough the machine will shut down and give the IE error or fault code. The most likely problem that will cause this fault or error code is that the water hose screens are plugged with dirt and debris. Most all washing machines have some type of water filter in the hoses or in the machine at the entering point for the water. Dirt and debris will build up in these filters till in restricts the water flow enough to cause this problem. The other cause for this error is if you happen to reverse the hoses. If the cold water hose is on the hot side and the hot is on the cold side it can also cause to alarm. If the filters look clean then check the location of the hoses and make sure that they are properly connected. Check that the water valves where the hoses connect to the domestic water supply are on completely. Some valves are difficult to tell if they are completely on or not. If you need to reset your washing machine fault or error codes you can do this by unplugging the machine and then holding the start/pause button for five seconds. Then plug the machine back in and the code should be removed.
Mar 15, 2010 | Kitchen Appliances - Others
washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
what fault code ie
The IE or water inlet error or fault code is to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Sep 12, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
15,854 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
