Tip & How-To about Computers & Internet
Some tools to reset windows 7 administrator login password
There are a lot of tools and utilities that can be downloaded and used to recover, reset, retrieve or reveal existing password. These windows password recovery utilities, free or paid, are usually a Linux boot disk or CD that able to comes with NT file system (NTFS) drivers and software that will read the registry and rewrite the password hashes, or can brute force crack the password for any user account including the Administrators. The advantage is that there is no fear of leaking your password to outsiders, while the process requires physical access to the console and a floppy or CD drive, depending on which tool you choose. And it’s not easy, although it always work!
Below is the most famous recovery tool I found:
Windows Password Recovery Tool 3.0
– it is the most popular Windows password cracker . It is a very efficient implementation of windows any versions. It comes with a Graphical User Interface and runs on multiple platforms.
Password Recovery Bundle –This is a utility to reset the password of any user that has a valid (local) account on your windows system. You do not need to know the old password to set a new one. It works offline, that is, you have to shutdown your computer and boot off a floppydisk or CD. It’ll detect and offer to unlock locked or disabled out user accounts. It is also an almost fully functional registry editor.
Windows Password Key 8.0 -It is considered as the best tool to reset local administrator and user passwords on any Windows system. It creates a password recovery CD/DVD, USB Flash Drive for home, business and enterprise. And most of all, it's the most popular and safe solution for removing your Windows password until now.
Computers & Internet Logo
It says ys this computer is protected by Password Authentication system. can't access the bios or every thing give me master bios password for INSPIRON 6400 dell laptop with service tag CV5RW2J-595B
You can remove it with windows 7 password tools. For removing Windows login Passwords safely, I strongly recommend Windows Password Reset 9.0. Few days ago, I downloaded it at http://www.reset-windows-password.com I burned it to a Usb memory card. Booting up and clearing my password within just 5 minutes.
Aug 24, 2010 | Dell Inspiron 6400 Notebook
i need to reset administator pass word for windows vista but i cant down load anything cus i have to be in the administator mod
There are a lot of tools and utilities that can be downloaded and used to recover, reset, retrieve or reveal existing password. These password reset or retrieval utilities, free or paid, are usually a Linux boot disk or CD that able to comes with NT file system (NTFS) drivers and software that will read the registry
Offline NT Password & Registry Editor – Available as bootdisk or bootable CD, Offline NT Password and Registry Editor works to change or reset password of any users on Windows NT 3.51, NT 4, Windows 2000,Windows XP, Windows Server 2003, Vindows Vista 32 and 64 bit. It can also detect and offer to unlock locked or disabled user accounts.
Download Links:
http://home.eunet.no/~pnordahl/ntpasswd/cd080802.zip
http://home.eunet.no/~pnordahl/ntpasswd/bd080526.zip
Let me know how did it get out.
Sharon
Feb 02, 2010 | Microsoft Windows XP Professional for PC
FORGOT PASSWORD
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} In addition to reinstall your system, the easiest way to solve the
problem is to use some Windows Password Reset program. The
program will enable you to reset the password to "Blank" with no
-reformatting or installation. Do all the job for you automatically. It's worth a try.
http://www.resetwindowspassword.com
Jan 03, 2009 | Acer TravelMate TM2480-2705 Notebook
Forgot my Password
If this is a Windows password, start up in safe mode, log in as administrator, from here you can clear any user passwords.
Jul 11, 2008 | Computers & Internet
Cant Log on my com. LOST PASSWORD.
This comes from Yahoo but the last time I recovered a lost pass I hooked the drive up as slave on another machine and used a program to search for the pass on the old drive.
Method 1: Take a rest, and try hard to remember the forgotten password
Sometimes, human being is a little weird. You won’t get the thing that you urgently need. So have a coffee, take a snap or even come back after a few days, you may found that you suddenly ‘remember’ your Windows password.
Method 2: Try No Password Administrator Login Backdoor
In Windows XP (not Windows Vista as Administrator account is not enabled by default), there is built-in Administrator user account, that has administrative credentials, enabled by default, and without any password to protect the account from been access. If you didn’t change this Administrator’s password, then try to sign in to Windows XP without password.
Method 3: Reset password from another user account with administrator credentials
If you cannot log on to Windows by using a particular user account, but you can log on to another account that has administrative credentials, follow these steps on how to do the trick:
Log on to Windows by using an administrator account that has a password that you remember. You may need to start WinXP in safe mode.
Click Start, and then click Run.
In the Open box, type “control userpasswords2′, and then click OK.
Click the user account that you forgot the password for, and then click Reset Password.
Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Method 4: LOGON.SCR password reset trick
LOGON.SCR changing administrator or domain admin password hack works on Windows NT 4.0 and some versions of Windows 2000. The simple trick uses Cmd.exe as screen saver that triggered by system when idle, allowing users to access to command prompt to change password.
Method 5: Do-It-Yourself (DIY) third party recovery tool
There are a lot of tools and utilities that can be downloaded and used to recover, reset, retrieve or reveal existing password. These password reset or retrieval utilities, free or paid, are usually a Linux boot disk or CD that able to comes with NT file system (NTFS) drivers and software that will read the registry and rewrite the password hashes, or can brute force crack the password for any user account including the Administrators. The advantage is that there is no fear of leaking your password to outsiders, while the process requires physical access to the console and a floppy or CD drive, depending on which tool you choose. And it’s not easy, although it always work!
Offline NT Password & Registry Editor - Available as bootdisk or bootable CD, Offline NT Password and Registry Editor works to change or reset password of any users on Windows NT 3.51, NT 4, Windows 2000, Windows XP, Windows Server 2003, Vindows Vista 32 and 64 bit. It can also detect and offer to unlock locked or disabled user accounts.
May 03, 2008 | Computers & Internet
176 people viewed this tip
David Payne
David Payne
