Tip & How-To about Refrigerators
How To Clean Stainless Steel Appliances
First do a quick wipe of the appliance with a gentle liquid dish detergent & water mix, dry with a clean towel. After washing you’ll likely see the smudges and marks still hanging in there. You can buff out each smudge with a lint-free towel and some pressure, but try one of these items instead to bring back the shine and quickly remove those pesky fingerprints and smudges:
  • Olive Oil (just a dab will do)
  • Mineral Oil (Baby Oil)–Just a dab will do
  • Club Soda (especially good for removing streaks and heat stains)
  • Rubbing Alcohol
  • Vinegar (great for polishing too)
Apply directly to a lint-free cloth and wipe down surface, follow up with a clean dry cloth to bring appliance to a mark-free shine.
  • Avoid using cleaners or cleaning tools that are abrasive since they can mar the surface (even some soft-scrubbing creams can cause damage).
  • When cleaning the surface, wipe down the appliances along the grain of the stainless steel for best results.
  • Don’t clean stainless steel with bleach (diluted or otherwise), this can damage the finish.
  • Don’t forget to open the refrigerator or oven door, you’ll likely see a mess of smudges along the edge of the door.
Refrigerators Logo
What is the best way to clean my outdoor sofa?
Firstly I would remove the cushions to ensure that they do not get saturated, then mix some dish washing detergent with water and gently rub the furniture with a cloth. To remove excess water and soap use an old towel to wipe it down again.
Feb 13, 2013 | Furniture
What is the best way to clean a 46" LCD Toshiba TV
You do not want to use any harsh chemical or anything in excess. What I use and recommend is simply water and dish soap such as ivory. Use clean lint free paper towels or cotton or soft fabrics. You put a drop or two of detergent on a damp towel.You gently wash the screen then wipe it dry. The towel needs to be damp but not enough so that you get any running water.You may need to do it in small sections. If you use too much soap you get streaks. If that happens just get another damp piece without soap and go over and then use the dry to wipe the screen dry. The soap takes off anything without harming the anti-glare coatings on the screens. The wrong type of alcohol or a harsh cleaner can strip these coatings off or damage the plastics. Dish soap and water is very safe dirt cheap and found in the kitchen usually. ;-]
Sep 02, 2011 | Toshiba 46SL417U LCD TV
it has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
243 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
