Tip & How-To about Garden
What to use when your glass patio door is really hard to open & close
Take a bar of soap and run it along the tracks, works everytime
Garden Logo
Power window slipped off track drivers side freezing temps
if your window has popped out of its track , a neet hack to get it back in is to use a bar of soap !! just rub a generous amount on glass edge and window track and gently wiggle the glass back into track (don't bend glass) use only an old credit card or your "cold" bare fingers to wiggle it back in , metal tools will break the glass 4 sure
leave the soap on windows edge it keeps ice from sticking !!
Dec 16, 2016 | Cars & Trucks
dishwaser will not empty the soap, does not matter if it is the cubes or crystals
Run it empy one time and see if it does the same thing. If it does then there is a water distribution issue. The spray bar is not getting enough water through it. If it does not work right when empty you should inspect the spray bars for plugged holes and then check the sump and pump area for debris. If the machine works when it is empty, check to see if you are loading it in a manner that obstructs the soap dispensor.
Jun 09, 2013 | Westinghouse WWBD2400HW 24 Inch Built-In...
when the cd player is running it suddenly jumps to other tracks or to the first track.
check the disc for marks or scratches, does it do the same for all discs? maybe take the player apart and check any running mechanism for obstructions, regrease the bar that the lens moves along.
May 02, 2011 | Yamaha Audio Players & Recorders
1999 grand prix, driver door window wont go up or down and is stuck in down position
I have had the same problem with my driver side window ,., it might go down but get stuck half way up and wouldn't go any further. take the door panel off and all the protective plastic , it goes back on easly enough, it might sound crazy but i took a bar of soap and soaps all the tracking where the window slides up and down and I sware it works better than my other window I mean it works better than when i bought it, try it you'll be glad you did
Jan 08, 2011 | 1999 Pontiac Grand Prix
826 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
